Differential upgrade?
Have a 74 mach1 and im wondering what you guys have done to upgrade the rear end
If you have the 8", there are options.
If not, swap to an 8", 9", or 8.8" to have options.
In my case, I'm running the following:
I don't recommend it for the street, but at the drag strip... as long as you have a tall enough tire and your engine can spin enough RPM, go for it.
Reactions: 2Blue2
Agree - the 8" is usually strong enough for most things you throw at it for a street car, and there are options for it. If you have the smaller axle, the best/easiest upgrade would be to find an 8" from another II and swap it in. As luck would have it I have an extra 8" sitting here doing nothing - where are you located? If you're fairly close I'm sure we can work something out if you'd be interested.
  • Hell Yeah!
Reactions: 2Blue2 and Enzio
Mustang II rear end upgrades
You need more than just a posi.
I like the locker a lot.
Popular posi options for the 8' and 9' inch rears are;
Locker ( can be noisy but that just means its working) Tough
Trac-loc (clutch style posi) Cheap
Trutrack (helical gear style posi) Doesn't wear out quick
Mini spool (dirt trac only, tears up axle ends on the street) Fun to look at
Full spool (Bad arse but not so great on street daily) guaranteed to squeal tires in low speed parking lot turns and rear steer car sometimes.
Sub Frame Connectors from Stumpy's Fab works are a must.(just do it)
Traction bars can be nice too;
slapper bars (universal old school)
Mustang II traction bars by Stumpy Fab works ( get to keep stock rear roll bar with these)
Calvert Cal- trac (a good drag bar available for MII)
The leaf spring to car mount is wimpy, it can have a piece of angle iron welded to it
This is post 144 from 429MII's thread
Thats the usual rear stock suspension upgrades for our M2s
Heres mine with drive shaft safety loop, stumpys subframe connectors, and shot gun style exhaust.
Come on Ed88 Post a fresh picture of your car please.
Sounds dumb but im not sure which rear end i have. How do you identify them? Im also located in Southern Illinois.
I'll post some tomorrow definitely
Reactions: 2Blue2
The easiest way to tell between the 2 is if the back of the differential has a cover or if it's "smooth." The one with a cover is the smaller rear, I think it's a 6.75 ring gear, the "smooth" differential is an 8 inch.
I took a look at the axle I have, I knew it was missing one of the brake baking plates but it's also missing an axle from the same side. I'm in the Atlanta area but I'm from Iowa, so I do travel through southern Illinois on occasion. I don't have any plans of making the drive anytime soon, but if you're not in a hurry I'm sure we can work something out if you want it. It's from a V8 car, I believe it's a 2.79 gear with an open differential.
An 8 inch for reference:
All of the II 8 inch rears that I've ever seen don't have that plug that's more centered in the housing. The fill plug is on the pinion side in the carrier.
Reactions: Enzio
Got busy guys but here she is.
That old car is in pretty good shape,
Looks like an original paint Mach I, Wow! neat!
What color is that ? Ginger glow? First 2 yrs only? IDK
Always liked that Mach I package. Thanks for sharing
inspiration picture
