Hello all:
I have a couple questions about my motor setup as I recently got it up and running.
It's a long story but I purchased a built motor and transmission from a long time family friend. He paid to have it built but never ended up using it. He left it in climate controlled storage for a while and eventually basically gave it to me for next-to-nothing.
Everything listed (minus the intake manifold, injectors and MAF) was built and assembled by DSS Racing and it's how I got it. Admittedly the setup is probably a little strange, but it's all I have to work with at the moment. The motor was built for a street/strip car with an emphasis on strip. My car will not be a daily driver so that's fine. The setup is:
DSS 306 block with main girdle and windage tray
DSS Forged Pistons
DSS Forged Rods
Mircopolished crank
1.6 Scorpion roller rockers
Ford Racing X303 cam
Trick Flow 58cc twisted wedge heads
Explorer upper / lower intake
Pro-M 30# injectors
Pro-M 75mm Mass Air
Areomotive Fuel Pressure regulator
Stock TB
(Shouldn't be relevant for this discussion but it has a built C4 transmission with a 2800 stall, hammer shifter, and 3:73 gears.)
A couple weeks ago I asked about timing. Basically, I was/am a complete novice and had no idea what I was doing. After taking the advice given on the thread, I got the car to start, and I set the timing at 12 degrees. It was running at about 650rpm's. However that was only accomplished by also jacking up the throttle screw to a fully open position. This also made the engine very choppy and it often sounded like it was going to die. (I realize the X-cam is a very choppy cam, that adds to my confusion) It also made setting the base idle difficult even with widening out the screw holes.
So on to the meat of my questions...
For comparison sake, here is my car at it's current idle: (shes been sitting in the garage for a year and a half so she's filthy)
View: https://www.youtube.com/watch?v=pnjh5YeI64k
Here is another video I found, supposedly with an X-cam:
View: https://www.youtube.com/watch?v=SfhPNZg2Zew
But then also this one:
View: https://www.youtube.com/watch?v=jhIC4kglNLw
Maybe comparing the idle isn't helpful but again, as a total novice I am just trying to get myself into the ballpark. I'm not expecting the car to run perfectly with a stock computer in it, but I feel like I should be able to be confident in it's ability to tool around in, which at this point I am not.
Any questions or clarifications please reach out.
DSS Forged Pistons
DSS Forged Rods
Mircopolished crank
Pro-M 30# injectors
Pro-M 75mm Mass Air
Stock TB
- I have read on The Corral, and on previous threads here on Stangnet that the idle with an X-cam smooths slightly and it is more stable around 800 rpms. Does anybody have experience with that?
- Is that what I should be shooting for?
- At 12 degrees currently, the distributor is nearly hitting the thermostat housing. That, combined with the throttle screw being all the way open and it running pig-rich, makes me wonder if I might be a tooth off on the dizzy. How does one tell if your are a tooth off? I found TDC and the rotor does appear to be pointing at the number 1 spark plug, but I am just asking.
- Is it possible that I just don't know what I am talking about and the thing is idling fine?
