92 LX Uneven Front Bumper
lojo1
31
25
18
Charlotte, NC
I've heard of several Fox Body owners having issues with the front bumper drooping on one side. Mine seems to have that same issue but looks more like it may have been run up on a curb or some other surface. My question is should the drivers side be higher or should the passenger side be lower? I just need a general direction to start in.
Thanks, Lojo-1
Did you measure each side? It's hard to tell in pic because pass. Side is in sunlight and drivers side shadowed.I
All I see is the droop at inner opening,which I also have.
Reactions: lojo1
I did not but I will when I return home. I have also noticed my driver's side sits about an 1/2 inch lower than the passenger side. I'm sure that has something to do with it.
I'm changing out my struts and tie rods this weekend. Gonna check and make sure the lowering springs are seated properly on the drivers side.
