Blue85 Member Dec 25, 2020 86 13 18 Florida May 1, 2023 #1 May 1, 2023 #1 Do you think the coil would get too hot if mounted just above the intake? Never thought I would have a problem drilling holes in an engine bay. I really don’t want to. Attachments A6808F86-02C2-49B7-941A-279B0C024C15.webp 482.9 KB · Views: 131
General karthief wonder how much it would cost to ship you a pair 5 Year Member Aug 25, 2016 27,842 10,516 203 polk county florida May 1, 2023 #2 May 1, 2023 #2 The designers put the coil on the inner fender to remove heat and vibration issues that could (and did in some instances) occur. This is, of course, just a rumor and not based on any real evidence that I know of
2000xp8 SN Certified Technician Aug 8, 2003 8,016 1,613 194 NJ May 2, 2023 #3 May 2, 2023 #3 If that's an msd coil it will probably fail without the heat, so i can only imagine what will happen over the intake. Reactions: General karthief
Mustang5L5 That is…until I whipped out my Bissell Mod Dude Feb 18, 2001 43,172 17,871 224 Massachusetts May 2, 2023 #4 May 2, 2023 #4 Ford somewhat put the coil over the intake on the 94/95 Mustang and on the 91-93 Cougarchicken. These are the same coils as our fox cars 5.0 exploreres use a different wasted spark type coil, but they are where the dist used to be. 4.6L Mustangs also use engine mounted coils, and moderns cars all literally stick the coils in the spark plug holes.
limp wrap a little cheese around it and its a done 5 Year Member Oct 4, 2020 5,461 2,890 173 Florida May 2, 2023 #5 May 2, 2023 #5 Blue85 said: Never thought I would have a problem drilling holes in an engine bay. I really don’t want to. Click to expand... Bring it over to my house, I'll drill em for you.....
General karthief wonder how much it would cost to ship you a pair 5 Year Member Aug 25, 2016 27,842 10,516 203 polk county florida May 2, 2023 #6 May 2, 2023 #6 Curses, another hair brained theory busted
AeroCoupe lube between the nut and the face. I know my lubes Founding Member Oct 28, 2001 5,796 3,928 183 Claremore, OK May 2, 2023 #7 May 2, 2023 #7 I mounted a TFI coil on my carbureted 83 T-Bird like Limp did. Reactions: limp
Blue85 Member Dec 25, 2020 86 13 18 Florida May 3, 2023 #8 May 3, 2023 #8 2000xp8 said: If that's an msd coil it will probably fail without the heat, so i can only imagine what will happen over the intake. Click to expand... Not a MSD but I think it’s a cheap one. Got it from a buddy with a MSD distributor.
Blue85 Member Dec 25, 2020 86 13 18 Florida May 6, 2023 #9 May 6, 2023 #9 I think I’m going to the fender well on the passenger side behind the strut tower. So far this will be the only thing mounted.
Blown88GT Founding Member Nov 13, 1999 2,282 522 164 Palm Beach Gardens, FL May 6, 2023 #10 May 6, 2023 #10 I left the original coil alone. Mounted the performance coil here. Needed a longer coil wire. Attachments DSCN0247_cr.webp 260.3 KB · Views: 116
Blue85 Member Dec 25, 2020 86 13 18 Florida May 6, 2023 #11 May 6, 2023 #11 I really want to put it in the car.
