Should not be as the pickup for the oil pump is on the rear of the pan.
Check the output of the coil first by unplugging the coil wire off the dizzy cap, put screw driver into plug end, lay screw driver next to a good ground (use a strut mount bolt), roll motor over and look for spark. Next, roll motor over until on TDC and check where the rotor in the dizzy is pointing. Should be on the #1 cylinder post on the dizzy cap. What firing order did you use?
