Progress Thread Snow - 93 GT Vert. Prepping for sale
Should not be as the pickup for the oil pump is on the rear of the pan.
Check the output of the coil first by unplugging the coil wire off the dizzy cap, put screw driver into plug end, lay screw driver next to a good ground (use a strut mount bolt), roll motor over and look for spark. Next, roll motor over until on TDC and check where the rotor in the dizzy is pointing. Should be on the #1 cylinder post on the dizzy cap. What firing order did you use?
Just drill a 1/8" hole in the top part of the thermostat and install the thermostat so the hole is at 12:00. Been doing this for years and never have a problem with having to bleed the coolant system.
Reactions: limp
It’s lined up where I intended it. Harmonic balancer says TDC and dizzy is pointed where I wanted it. Pointed at spark plug 1 on the cap. I’ll add my reference pic in the next post.
Ok, don't start jumping around, check and recheck, pull the #1 plug, turn the engine a complete rotation, as the piston comes up to TDC you will feel air pushing out the plug hole, I stick a screwdriver in to feel piston movement, stops moving up the 0* hash mark on the balancer will be at or very near the pointer, you marked #1 on the distributor right? Make the rotor point to that mark and it should start, then you can set timing with a light.
Reactions: JAA
Second pass sounded much better as I moved literally a tooth. However, started smoking. Looked to be both sides of exhaust manifold?. Smelled closer to plastic. Could be exhaust? Could be some of the 3 gallons of PB Blaster I used? Ill try to get a better vid.
