N NooStang Member Mar 15, 2024 42 6 18 Tn Jun 27, 2024 #1 Jun 27, 2024 #1 If not too much trouble, hoping someone could measure the air filter box base standoffs - height and diameter, excluding the threaded section. Attachments Box.webp 8.7 KB · Views: 140 Last edited: Jun 27, 2024
85GTStangGuy 5 Year Member May 19, 2021 1,003 625 133 Jax, Florida Jun 27, 2024 #2 Jun 27, 2024 #2 Don't know the dimensions, but if you're looking for the actual parts.... https://lmr.com/item/LRS-9686K/1986-93-Mustang-Air-Box-Hardware-Kit
N NooStang Member Mar 15, 2024 42 6 18 Tn Jun 27, 2024 #3 Jun 27, 2024 #3 Thanks for the link, but was planning to just 3D print a couple. Reactions: limp and 85GTStangGuy
Noobz347 Stangnet Facilities Maint Tech... Er... Janitor Admin Dude Jan 4, 1985 43,268 21,446 234 Box behind Walmart Jun 27, 2024 #4 Jun 27, 2024 #4 In PETG, PLA, or ABS? I don't think the PETG is going to hold up well in the engine bay (what most folks print with). ...and isn't it [hot] where you live?
N NooStang Member Mar 15, 2024 42 6 18 Tn Jun 27, 2024 #5 Jun 27, 2024 #5 Will try ABS. If ABS can't stand temps then I will break out the lathe once I get dimensions correct. Reactions: Noobz347
Noobz347 Stangnet Facilities Maint Tech... Er... Janitor Admin Dude Jan 4, 1985 43,268 21,446 234 Box behind Walmart Jun 27, 2024 #6 Jun 27, 2024 #6 NooStang said: Will try ABS. If ABS can't stand temps then I will break out the lathe once I get dimensions correct. Click to expand... I think the ABS will hold up under the hood for the airbox as long as it's not around oil and grease. Reactions: General karthief
