Progress Thread Snow - 93 GT Vert. My first Ford, Mustang, convertible, ...
What does it mean that my PVC doesn’t have a valve and just a tube? Am I supposed to use this valve and then block off the top tube connector? Does something else go there?
Well this is annoying
Brand new EGR leaking in the same way as before :(
My real issue is the lower intake PCV port. Is there a trick to stop vacuum leaks here? In some advertisements I see o-rings. Is there supposed to be o-rings here?
Start the engine, open the oil fill cap. Does smoke puff out? Hold your hand over the hole sealing it off, can you feel a little vacuum pull?
BTW can you take a vacuum reading?
Some have experienced oil splash at the back of the manifold/lifter valley area getting sucked up into the PVC screen/valve, the baffle in there is pretty small compared to later manifolds but I believe this issue was on drag/road race cars and possibly the use of high volume oil pumps.
For pics of the baffle difference check the last page or two of my 'slow-progress ' thread.
No smoke
Small vacuum. Car starts to think about stalling when opening the cap.
