prolly a computer the factory installs in several models with the same engine.The part number on the EEC came up for an E-250 Van?![]()
Sorry for the weird wording in the first post I didn't know if having a Lincoln was forbidden or not on this page but the car itself has the original engine. Although I recall doing one thing that could be causing my issues (Not sure though but I want to give full disclosure) when I did the wiring for the T5 transmission I hooked up the safety switch. From what I've read the big difference between an auto and manual computer is how the car restricts the user from starting the car in a manner that could cause damage.prolly a computer the factory installs in several models with the same engine.
I really didn't look too much on the numbers, this kindle can be stupid at times, needed year of body and what the engine came out of.
He'll be back in a few .
I hope![]()
This would be a computer that matches that model if I type in the number on Rock Auto it does show results for the 1986 - 1987 Lincoln Mark VII and Mercury Cougar. If it helps this vehicle was sold and imported from California so there could be a difference in part numbers with the different emissions standards.Ok, 1986 Mark ll with the original engine. Check.
You need to find a computer that matches that model, if that's the original computer then send it out to get checked,
Problem started after trans swap then go back and make sure the wiring ain't pinched someplace, grounds in place.
The switch for the clutch peddle is just for the starter, nothing there to effect the running, only cranking (as far as I know)
Judging by your video, and all the times i screwed around with a tps it shouldnt be bouncing around like that
Yes running the original stock coil, its got 83,000 miles on it.Couldnt tell from your pics, maybe i missed it but are you running a stock coil?
