Electrical Where to wire in a kill switch besides fuel pump relay
AnthonyA1234
5 Year Member
Aug 17, 2020
671
111
63
Florida
I want to wire in a kill switch in my fox for theft prevention. I did a wire tuck so my fuel pump relay is under the fender now so I can’t do the kill switch there like I see everyone recommends. What’s another easy to get to place where I can splice in a kill switch?
Relay behind the rear trim panel that interrupts the inertia switch. You can use a ground to to trigger it and bring the switch up to the front of the car or where ever you want.
Bosch Relay
Put the wire coming to the inertia switch on 30 and 85, 87 would then go on to the inertia switch. 86 would be a switch triggered ground.
Thanks for the suggestions. Now that I think more about it, I could still do the fuel relay kill switch on the red wire. I can just get the wire where it starts, which I believe is at the pcm relay in the passenger kick panel. I’ll cut that wire and splice in a switch there.
So I got to the eec relay. I have two red wires going into the relay. Which should I cut and put the kill switch into? One of the red wires goes down into the computer, the other one goes out and through the firewall to hopefully the fuel pump relay. I’m planning on cutting the one that goes up off the relay towards the fuel pump relay. Can anyone just confirm this for me that this is correct.
Here’s what I read in my electrical diagram book, it shows that the red wire comes out of the computer, then is at the eec relay, then the fuel pump relay. It’s listed as 361 vehicle power.
If anyone can confirm this is right for the kill switch and I should cut the one coming off the eec relay and heading up towards the firewall I’d appreciate it
I cut the wire and spliced in the switch where I showed I was in my previous posts and it still starts and runs the same with the switch on or off…
Anyone know what I’m doing wrong here
This is what I did
I’m looking at this diagram I found of foxbody wiring. i suspected maybe that switch was bad and was stuck on all the time. I disconnected the wire so that the circuit is completely broken and the car ran fine. I don’t understand how my car could still run the same and everything works being as though I cut that red wire….
You could use a momentary switch for the trigger wire to the starter relay.
Engine won't crank unless the momentary switch is held while key is in crank position.
Fed X trucks use a momentary switch to get the transmission out of Park position.
Truck will start and run but the shift lever will not move out of Park without pressing the switch.
Reactions: AnthonyA1234
