It's been a while since I've done anything really productive with either of the Mustangs.
Well, I did finish the fuel injection install on the Cobra but stalled because the water pump is leaking and I need to get the accessory drive ironed out, but that's going to have to be saved for another post....
BUT, I just bit the bullet and ordered a Marti report for both the Cobra and the GT. I'll share them when I get them, but I'm going to give this disclaimer RIGHT NOW - the Cobra isn't a real Cobra (as I'm sure most of you already know....) - it was a black Rallye package.![]()
Pretty neat options on your Cobra-is it still an Ac Car?And here's the Marti Report for the Cobra...... um...... II.
No, I removed it all when I had the car torn down. I was still in Iowa at the time and AC wasn't such a big deal or concern. I really wish I would've kept most of the components now that I live in the ATL. I keep thinking that I need to find a donor or replacement just to get the AC system back.
Ooops.... 7[9] to 82.
Still... how tough could it be to shoehorn a Fox kit into a II?![]()
I've kind of wondered about this option - like how different are the hvac boxes between them anyway? Figuring out the controls is the easy part really.![]()
I've seen full Fox dashes swapped into a II so....
This is something I don't think I've ever seen....![]()
Your crank pulley is smaller than normal, right?The aluminum tube isn't supposed to be delivered until Wednesday, but I got most of it thrown back together and got a more accurate measurement for the tube. I also had to order a new belt, the one I had with the original brackets is too short. So when those finally arrive all I should need to do is cut the tube to length, install it, reinstall the radiator and hoses, install the new belt, fill it with coolant, then fire it up.
It's not about how big your crank pulley is; It's how you use it.Your crank pulley is smaller than normal, right?
So it slows down the water pump and accessories. I had one on my drag Falcon but never used one on a street driven car.I believe it is.
