Somewhere I mentioned project creep. Yup, there it is
Everyone is about to witness a magnificent illustration of "project creep" this winter
I was going to do all this over the next 2-3 winters but in the interest of not taking things apart so many times and re buying parts to accomplish the same end goal I decided to do it all at the same time. Goal is to be ready by spring, but it might go into summer a little depending on available time.
Next up is a bunch of work I'm breaking this down into 3 phases.
-Engine/engine bay/clutch
-Fuel system
-Stand alone EFI setup.
I'll be removing the engine and adding a Trick Flow 360 hp top end kit. It's pretty inclusive with heads, intake, cam, rockers, valve covers, timing chain, pushrods and other little bits.
This will pair well with my Vortech V3 Heritage. I'll be dropping down from the 10+ psi I'm currently running to around 6-8 psi and expecting around 425 hp. In that neighborhood anyway. I'll also tidy up the engine bay a little.
The parts list is long but some basic stuff beyond the TrickFlow kit will be a block clean up and re paint, ARP head and intake studs (ARP fasteners throughout). A new melling 10687 oil pump and ARP oil pump drive shaft, new oil pan and pickup tube, 75mm Acufab TB, harmonic balancer, edelbrock water pump, engine mounts and so on.
The clutch is a McLeod RST twin disc with a Ford Performance billet flywheel. ARP Flywheel bolts, a new Motorcraft TO bearing and other small parts. I like the idea of the increased holding power and light stock pedal feel of the twin disc. So looking forward to that.
Fuel System:
After giving the original fuel lines a good lookover I decided it best to replace them. I also wanted to run a larger feed and return. So I'll be doing the fuel system similar to the brake system and replacing everything at once. I'll be replacing the system from the fuel tank to the fuel rails.
Going in:
-Aeromotive 18638 fuel pump hanger with 6an feed and return fittings
-Fragolia 6an PTFE fuel line, braided stainless with black plastic outer cover
-Fragolia black AN "street" fittings
-Aeromotive 13136 fuel pressure regulator
-Aeromotice 12347 fuel filter
-Anderson motorsports fuel rails
-Finish Line Factory PTNH-8AN Cross-Mount Dual Hose Separator to secure fuel lines
-Rivnuts to mount separators to chassis.
For the standalone I decided to go with a Pro-M efi setup with a crank trigger wheel setup. That order will be going in soon.
I do have plans to replace the T5 with a TKX. It's possible I'll do that this winter time and budget depending. I'm thinking this summer will be largely learning tuning and breaking in the new clutch. So I feel comfortable the T5 will survive at least this summer.
Stay tuned.
