My First Dump Truck
RaggedGT
Mod Dude
Jul 20, 2014
4,751
3,206
203
Taylorsville ky
Well guys,I’ve been looking at buying some larger equipment for my own personal use to do dirt-gravel and eventually concrete work around my home and garage.
Side note, I work for the local transit authority . A few times a year they liquidate stuff on govdeals.com
Look at this Dead Sexy SonofaBiach I just acquired-
1975 F-600 Dump Truck
330 FE, 4-speed,35K Original miles.
The good- the cab is rusty, been fairly well maintained , has been parked inside on concrete the last couple of years.
The Bad- it got parked because it needs the frame mount vacuum brake booster replaced-and it’s basically unobtainium at present
The 2150 Carb needs gone through and the old fuel drained out, but hopefully I’ll have it home in the next week or so
I know nothing about those boosters, but is this it?
It at least looks similar. :shrug:
New to me brake booster showed up Friday, went Monday morning after work to the storage barn and installed it. Went about as expected, rusty brake lines and bolts that had to be ground off. Put a kit in the carb. Topped off the fluids, swapped the battery-and it started like it was parked yesterday. Proceeded to bleed the brakes-luckily all the bleeders cooperated . Everything bled out well,nothing was leaking, engine stayed cool. Left on the maiden voyage for my 40 mile road trip home, brakes lasted about 4 blocks lol.
Did a road side check,found no leaks-reaivoir almost empty. Filled it up and bled at the remote booster. Had perfect brakes again. Over the next 4 hours the brakes would fail roughly 4 more times-fortunately I live in a rural area and was able to limp it home using the clutch and a mix of the flange brake .
Update: After the used booster turned out bad-I bypassed it. Manual brakes on this truck is pretty stupid,so I barely used it last year.
Found a company that makes an upgrade kit-decided to not pay what they charge for the kit and bought the modern Booster and master cylinder- combo valve etc. when the weather permits. I’ll have power brakes again
