Fuel Pressure Regulator rebuild
Scrapla347
205
70
38
Florida
My BBK fuel pressure regulator went bad. It's leaking fuel and sucking fuel into the vacuum hose. The car sat for over 10 years so I'm assuming the diaphragm dry rotted. I see a kit on BBK but it says it's for 2010 models and newer. Mine if from 2008. The only difference I see is the vacuum port which is on top on the newer models but on the side for mine. I emailed them and they said it's the only rebuild kit they sell and I have 30 days to return if it doesn't work. Has anyone replaced the diaphragm on their regulator and know if this kit will work on older models?
Did you find your answer? Here's your bump :cheers:
I removed the regulator and took it apart. The diaphragm seemed dry and started to separate. I bought a rebuild kit from BBK which fit but the rebuild kit had a different diaphragm which looked way better than the old style but the new spring was smaller and looked cheaper. If it leaks again I'm just ordering a OEM unit and calling it a day. Thanks for the bump!
Reactions: 89ripper
