Suspension Mustang 2 motor mount
302 mounts are elusive. Classic Auto Reproduction has them on their site, but they're on back order.
If you still have them, there's a rebuild kit, also available from Classic Auto Reproductions.
I'm not aware of any reproductions or rebuild kits for anything other than 302s.
Hello everyone.
I'm currently converting my Mustang II to a V8 and ordered these engine mounts from Classic Repro.
They're made slightly differently and have different sides.
Can anyone tell me, or provide good pictures, how to install the engine mounts correctly? Unfortunately, there are no signs.
The mount with the slotted hole is for the right side. You will also need the frame brackets for a V8 to be able to attach the motor mounts to the frame, 6028 (RH) and 6029 (LH) in the illustration below.
As far as I know, no one reproduces the frame mounts. So your best bet would be EBay or a specialty supplier/salvage source such as Phil Schmidt in Alabama. Unfortunately I don't have any contact info for him, but I'd suspect it wouldn't be too hard to find if you did a search. I believe he's on Facebook as well, so that may be your best bet to get a hold of him if you have a profile. Look in the Mustang II groups, I'm pretty sure he's active there.
Reactions: LILCBRA
Since you are swapping in a V8, you will also need the oil pan and pickup tube for a Mustang II, and the Mustang II bell housing, flex plate and torque converter (if using and automatic) or Mustang II flywheel, clutch/pressure plate and bell housing (if using manual trans). A donor car is the best route to get all the Mustang II specific parts you need.
You can try via kleinanzeigen.de
Look for Salzwedel and Mainz. There is also a scarp yard in Netherlands which was quite helpfull and has a lot of Mustang IIs. I bought my clutch pedal assembly there. I will send you the info via PM.
I heard today from German forums that the V6 and V8 seem to have identical frame mounts, only the 4-cylinder has different ones.
I searched for V6 engine mounts and found them; they also have the same distance between the bolt-on points on the frame mounts.
I hope it's true that the V6 and V8 are identical.
Now I have a minor problem. My motor mounts are from Classic Repro and don't have markings like left and right, but there is a longer and shorter side.
How do I install them so that the motor is positioned correctly?
