Strut rattle
JD1964
there is enough sticking out to grab on to
3,462
1,550
194
Maryland
Ive got Lakewood adjustable front struts and UPR camber plates. All the bolts are tight but I still hear the rattle. Most noticeable crusing through hood no load roughly 25mph. Is there a trick to quieting these down? What other components should I be looking at? Sway bar mounts and end links look good. Tie rods and ball joints have no play.
Thanks for the idea. Ill check the calipers. However, i can roll forward or backward slowly and stomp the brake pedal. No noise. If the calipers were loose then wouldnt they clunk if there were loose?
Do you have isolators top and bottom?
Are there any plastic boots/etc. inside the coil spring that might be flopping around or catching on something?
Have you looked at you engine bay skirts? Is everything tight/not flapping in the breeze?
Is there [anything] that looks like might move in turbulent air? O_o
Did another test drive after making double sure all camber plate and strut mount bolts are super tight. Still rattling. I also tried coasting and applying slight braking to see if engaged calipers changes the noise. No change
Spring isolators on top and bottom. Plastic splash guards are a little loose but I seriously doubt they would make the kind of noise I’m hearing.
Is the spring free and clear of everything (imagine some slight articulation)? Can you rock it back and forth by hand, so that it's not?
I chased something like this down on an F-150 once. Drove us nuts, all OEM parts. In our case, it turned out to be an old bushing we played hell, finding.
Rattles and Thunks, drive me nuts.
Not that I have far to drive. :shrug:
I unbolted the top of the struts and removed the spherical bearing retaining ring. The spherical bearings are tight and have no slop whatsoever. So I can’t see how replacing them would solve it.
