Fuel 93 5.0 fuel problem
Hello I have a 93 5.0 with GT 40 heads swapped in to a 65. Recent problem I have now is too much fuel. If I start it up runs rough and black smoke. Pulled plugs smell like gas. But If it pull the fuel pump relay it starts an runs great until it runs out of fuel. Any suggestions what is causing to get too much fuel? Thanks Brian
Have you checked for any codes? If not and if you do not know how then go here:
Have you checked the fuel pressure? Have you checked for fuel in the vacuum line that connects to the fuel pressure regulator? If there is fuel then it’s a sure sign the regulator is bad.
Could be the return line is pinched or kinked.
Code 23, 67, 81,82, 85
On a Foxbody Mustang 5.0, code 23 indicates a problem with the Throttle Position Sensor (TPS
Others are Emission codes
TPS wouldn't cause my problem would it? Again with fuel pump replay pulled car runs good until all the fuel in the rails is gone. With fuel pump running sputtering a lot of black smoke.
Well let’s see here…Code 23...yes it would cause problems. ECU looks at the TPS position so if it’s providing bad info to the ECU then the ECU will output bad info. Need to fix this.
Code 67 will not let you run KOER diagnostics so you may be missing codes related to that test. See this thread:
So see about fixing those two codes, clear the codes, get the motor up to operating temperature and then dump the codes both KOEO and KOER.
So you had a Tweecer on it and evidently the car was tuned and ran well. You pull the tweecer off and now it doesn't run well. Can you pop the tweecer back on and see if it runs right or did you change things since it was removed? Does it now have the stock MAF and injectors or a calibrated MAF and larger injectors? Basically is there anything in the motor that is not stock other than the GT40 heads?
Car started running bad with the Tweecar still installed it ran decent then it didn't. Where to begin it's a 93 Cobra S VT block and GT40 heads fresh rebuilt with mild cam. Intake is off an Explore larger throttle body new mass air, JBA headers, painless wiring harness, A9P ECM, Tanks intake fuel pump, Tweecar tune but could never get that to run right or hook up. All in a 65 coupe. A smarter guy would have just put a carb on it and drove but after investing years and money here I am and here it sits. It ran decent before just idle issues now black smoke. Thanks for the help.
It never ran great but good now horrible with the Tweecar or Without. Only thing that makes it run great is priming the pump then pulling the relay. Car runs smooth until fuel runs out. Only thing I can figure is the ECM is firing all the injectors at once dumping fuel in every cylinder at once.
