Every time i do something to this car, i find 4 other things wrong with it. A smart man would have not supercharged it, and put that money towards making it more reliable... but here we are ha haI hope your testing includes a Smokey burnout.
story of my life!!!!! I feel ya!the amount of times my wife has asked me how much i've been spending on the mustang as of late...
I’ve been looking more closely at my GT length drive belt. When I first installed it it was at the “G” on the “RANGE” lettering on the tensioner. Now, as I’m standing here tonight it’s at the “E”… so I definitely think my GT length belt is too long. This one is 91.56” in length. The Cobra belt I have is 88.9” and I couldn’t get it around the pulleys (which is why I reverted back to the GT belt). So I need a belt in between those two lengths. LMR has another Gates belt measuring 90.31” which I think would be perfect, but when I look up that P/N on oreillys site for example, it says 90 13/16 which would be 90.81”. 1/2” seems kind of significant. I’ll probably buy that Gates belt and see if it works.You can remove the S/C belt. It will start and run fine. Then you can be sure which one it is. I'd start there. If it's not the S/C belt causing the squeal....
Check that the tensioner is properly aligned. My instructions weren't accurate as far as how to attach it. The bolt that goes on over the water pump stud can pull it too far in (or out). I believe my instructions called to add a nut on it, or replace the nut with a different one. Can't remember, but it it was wrong. If I followed the instructions it was crooked and squealed.
The best way to install it is to only install the 2 bolts that hold it to the bracket. Let the third hole sit freely on the water pump stud without touching any extra nuts or anything. Tighten the two bracket bolts and it will be square to the bracket. Then measure the distance between the tensioner bracket and water pump nut. Make a shim exactly that thick and put it between there.
