Traction Whipple stage 2
Ok so how to get you these cars to hook up Whipple stage 2 cradle lock out sway bars 19x11 on 305/35/19 nittos R2. Even running them on 15psi good burnout. I still can’t hook up. I can’t even do a 60-130 pull without spinning. In hot temps. Help or advice with some experience would be appreciated.
Here's the short answer:
You're going to have to learn to drive the car.
You have roughly 800 HP to the wheels of a car that only weighs 3800 lbs. LoL
The alternative would be to make changes to the suspension until you get a wheelie out of it but... I'm not certain that you would appreciate the side effects on the street.
Reactions: Bullitt347
Learning to drive the car is a given. But when your making pulls and your spinning at any speeds under 65-70 mph with a drag radial lowered psi it’s not right. I was leaning towards some recommendations on more suspension parts to add to the springs cradle lock out and sway bars. Next summer I will run a bias ply. Before I play around more with the suspension.
Reactions: Noobz347
Turn the traction control back on.
