What's it Worth? Mustang GT Convertible Whipple Supercharged + $40K in upgrades
scregan
What's it worth
Extensively modified by a car loving professional (physician) enthusiast. FRPP Whipple Supercharger PLUS sent to Kenny Brown and BMR for a long list of supporting mods. Is lighter than, corners better than, and stops way better than a GT500.
List of mods includes but is not limited to:
Roush Front Fascia with LEDs all around
Ford Racing 550 HP intercooler supercharger with Ford Factory tune
Ford Racing KR Axle back mufflers
Tremec 6 speed XL Magnum high spread ratio .50 overdrive
Tremec NHRA certified bell housing
Mcloud Gt-500 1000 HP 26 sptine RXT twin disc clutch
Mcloud billet flywheel
FRP hydraulic throw out barring
3.5" custom aluminum drive shaft rated 1000 hp
Nhra certified Bmr drive shaft loop
9" Moser rear modular performance diff housing with fill drain plug & overflow vent
35 spline moser axles
Ps 028 aluminum Daytona support
35 spline wavetrac differential
3:90 gear ratio
Extended Nhra cert. 3" ford racing wheel studs
Custom dual adjustable lower control arms solid hiem joints
Bmr 9" adjustable upper rear control arm
6 way adjustable ford racing rear dampeners Steeda ultra lowering springs
Bmr adjustable panhard bar
Front steeda springs w/ ford racing 6 way adjustable shocks
Adjustable camber caster shock tower plates
Kenny Brown Build:
Bear Eradispeed rear 14" 2 piece slotted coated rear rotors with caliper relocation bracket
Baer extreme 6S black mono block 6 piston front calipers
Baer 2 piece 14" coated rotors
Stainless FRP brake lines
Ford racing big brake Gt-500 power calibration brake booster
FPR 3" stud Front hubs new bearings
KB front 3" brake duct kit and mount bracket
KB proforged bump steer kit
KB Jacking Rails (pr) - S197 05-14
KB Gen 1 Mustang Extreme Matrix Brace S197 05-14
Nitto 275/35/19 NT 05 (front)
Nitto 305/35/19 NT 05 (rear)
Reactions: MrPrice11
It’s a nice car. I don’t know what it’s worth...... but damn...... what the hell did they just drill two holes all off center like that for a plate! Do it right...... mount a bracket underneath, and all is fine. Little stuff like that ruins cars for me.
........ other than that, real cool car!
Seller said it was not bolted to the bumper. Must be some kind of bracket
