Is this a fuel filter?
Hey I just bought a 74 Mustang II, v6 engine. It’s been bogging down and occasionally dying too. I think it’s not getting enough fuel.
I would think the fuel pump would either be okay or dead, not like this where it’s kinda okay. I have fresh fuel with BG44k added.
I went to change the fuel filter and don’t see one at all. This has an aftermarket Weber carburetor. I was going to add one to the line and found this odd non-replaceable thing on the fuel line. Like a short cigar. Is this a filter or something else? If it’s a filter could it be clogged and causing the issue? Photo attached.
Thanks guys! And I’m new to owning classic cars so any advice would be helpful!
Welcome to :SN: !
It does kinda look like a filter..... I'd say that if it's spliced into your fuel lines that it most likely is, or it's some kind of check valve, but a filter seems more likely. A new filter isn't all that expensive, I'd say get yourself a new one and replace it and see where you end up.
Oh.... and before the hordes see your post and start badgering you - post up some pics of the car! Everyone likes to see them.
While it's not exacty like what you have, here's another inline filter to illustrate. They're meant to be r/r'ed, not serviced with a new element.
I'd suggest picking one up like this one so you can at least see what you may be working with.
I'd avoid the filters that you can take apart only because it's another potential point of leakage.
Reactions: DadLife0724
The part in your photo is not a fuel filter, it is part of the fuel vapor return (9G271). The fuel filter originally would have been threaded into the carb, item 9155 in the photo below. It may have been left off when the Weber carb was installed or replaced with one like shown in above posts.
The replacement filter looks like this:
2025-10-05 12_03_41-Motorcraft Fuel Filter FG14C _ O'Reilly Auto Parts — Mozilla Firefox.webp
Reactions: LILCBRA
2025-10-05 12_03_41-Motorcraft Fuel Filter FG14C _ O'Reilly Auto Parts — Mozilla Firefox.webp'Reilly Auto Parts — Mozilla Firefox.webp
Thank you - that's it! I appreciate the help, it's defintely the fuel vapor return. I'm guessing this is a smog prevention design, but not to prevent vapor lock or it would be closer to the carb.
Reactions: welder4956
