Oil Pressure Sending Unit Connector
Are your washers, lock washer and ring terminal brass?
I have a steel ring terminal, 2- steel nuts. I have 2 brass nuts I can use also.
I believe the connection on the sending unit is brass?
Not sure if it's wrong mixing dissimilar metals?
Thanks!
This is what I have so far. I'm going to add the washers and lock washer.
I cut the one off the factory harness years ago. Crimped a ring terminal on the wire, put a flat washer on the sending unit, ring terminal, flat washer, lock washer, and then a brass nut. Never had an issue.
This except I use a ring terminal for the auto meter electric then the factory connector on top ofit if I want that to work, sending unit ohm range is the same for the canister style and 2241 autometer uses with the short sweep gauges.
Reactions: 93gtmustang
You might be able to give the LMR connector a squeeze in the right spot to help it grip better
Yes, I tried that a bunch of times, but it kept coming off after a while.
The problem with the LMR connector is that is too small. When you finally get it on, its already out of shape and won't stay on.
I was going to try this one to if it was any better. https://www.npdlink.com/product/repair-harness-oil-pressure-sending-unit-repro/201582
But now I'm going with the ring terminal set up. At least it will stay on.
Thanks!
Reactions: gkomo
Thanks!
Your local parts stores should have them... Even Napa sells it for $6 and change.. ECH EC104
Thanks!
Some CT material in there, like" I have 2 brass nuts I can use also."
