Vib
65er
12
New Jersey
Hey All, 65er here again! Was hoping someone could shed some lite on this Vibration issue with my 65 base model. It feels like the tires are out of Balance between 30 + 40mph. smooths out to 50 then starts again, Motor has been replaced and is New, Trans and driveshaft have been rebuilt and has new Tires! To my mind, the only thing left to consider is Wheels and Axles! Any thoughts would be helpful! Thanks.
I would take it somewhere and have each of the tires checked for balance and also to make sure there’s not a defective tire. While they check for balance, they can also verify that you don’t have a bent rim. If all that passes, the next thing I would check would be front wheel bearings for run out. I’m sure others will chime in as well.
Thanks, I'll do just as you suggest!
