Interior and Upholstery 1993 Mustang Premium Radio interchangeability with other Ford radios.
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,122
224
Massachusetts
Decided to spin this thread off from my main thread here due to answering this question more frequently these days.
This thread focuses mainly on 1993 CD players for now, although there is some interchangeability for the 1993 premium tape deck as 94-98 SN95 radios are compatible. Same methodology for swapping the faceplate and tray applies
EDIT: 12/2/22
Made a video as well
View: https://youtu.be/EjmYRsjwJPg
The two PREMIUM radio option for 1993 look like below. There was a non-premium cassette player in 1993 that looks similar, but has manual
FF/REV buttons. It is not compatible with the 1993 premium amp setup
Since original 1993 radios are hard to find, I decided to make one. These CD players (and even the 93 premium tape decks) came in other 90's Fords. The main differences are the botton tray is unique to the 1993 Mustang to mount the storage cubby, and the edge of the radio faceplate on the Mustang is square, vs other radios being rounded over. Scroll down to post #3 for the list of radios from other Fords
The bottom tray problem is easy. ANY 87-93 bottom tray can be used if you have one. The square face is trickier to find. Ford used it on the radios they put in the F150 and F250, and possible the ford escort, so those faceplates can be used in the Mustang. Another difference is the COLOR of the radio. Some of the Fords used radios with BLUE color LCD displays and buttons. Most are green fortunately. A lot of faceplates being sold on eBay as “nos Mustang faceplates” are in fact for other Ford radios. Pay attention to the edges, preset6/clock and color of the lcd lens (green vs blue). I honestly have not seen a true NOS Mustang faceplate for sale for years.
I used a bad 1993 radio donor for parts. It didn't work at all. Buttons had wear and were broken. But, it had the brackets and square face frame i needed.
For a new radio, I picked up a 1999 Contour CD player. If you search around, salvage yards have these for about $50.
Here you can see the bottom plate in which the storage tray attached. These interchange between the CD players, so it was an easy swap. Some of the bottom plates clip on, while others are held on by small torx screws. Remove, and swap. Very easy. Now the bottom storage cubby fits on.
You can see the subtle differences between the faceplates below. Top one with the square edges is the Mustang. The contour radio has rounded edges. The faceplates come off very easily, but you need to be careful. Simply pry the faceplate off VERY carefully. I had already begun disassembling the faceplates to swap the good buttons over to the cd player face with square edges
The faceplates come apart very easily. All you need to do is remove the clear insert from behind by unclipping the tabs on the 4 edges. Then the buttons pretty much come out after that.
If you are using a 1993 CD player as a donor, the only button you really need to worry about is the 6th preset/CLOCK button. If your new radio has the 6th preset, you'll need to swap this over to your original 1993 faceplate. Pretty easy to do. Yes, you will lose some originality, but you are probably swapping in a Contour CD player so originality is out the window anyway.
A little parts swapping, and you now have a new chassis wearing the correct foxbody specific parts. A LOT easier than trying to find (and pay for) a working 1993 Mustang radio.
PLEASE BE ASVISED, a number of sellers have been selling “NOS 93 cobra/mustang radio faceplates” on eBay for a few years. If these plates do not have the squared edges and CLOCK instead of preset 6, they are not true mustamg faceplates. They are faceplates for the other various CD players sold in other vehicles.
SEE BELOW. This faceplates has a preset 6, and rounded corners. Not a Mustang cd faceplate
CD players
Here are the part numbers for various units if you want and try to locate some to use as Donors. The revision codes at the end (-AA, -AD) do vary so there may be more than what is listed below. I'm just listing actual part numbers I've seen
F3ZF-18C815-AC, -AD , -AE, -AF : OEM 1993 Premium radio Green Face, clock button, square face plate, bottom tray accepts storage cubby
Came in:
1993 Mustang Cobra w/premium sound
F3EF-18C815-AF : Square Edges. Possibly F150/F250
F48F-18C815-AE : Green Face, clock button, square face (like the Mustang)
Came in:
1992-1996 Ford F150/F250
Ford Escort
F4SF-18C815-AB , -BB : Unknown face color, has 6th preset
Came in:
1994-1995 Thunderbird Super Coupe
F58F-18C815-AA: BLUE face, and Clock button
Came in:
1995 - 1996 FORD Windstar
1995 - 1996 FORD Ranger
1995 - 1996 MERCURY Mountaineer
1998 LINCOLN Navigator
F78F-18C815-BA : Blue face, has clock button
1997 FORD Windstar
1997 FORD Ranger
1997 MERCURY Mountaineer
1998-2000 Mustang
95BP-18C815-AD: Green face, 6th preset
Came in:
1995 FORD Contour
1995 Mercury Mystique
97BP-18C815-AC
Came in:
1997 FORD Contour
1997 Mercury Mystique
98BB-18C815-AA:
Came in:
1998 - 2000 FORD Contour
1998 - 2000 Mercury Mystique
Reactions: BoostedRed89gt
Premium Cassette players
F3ZF-19B165-AB OEM 1993 Premium Mustang Cobra cassette deck - electronic eject
F3ZF-19B132-AC, -AD, -AE :
OEM 1993 Premium non-Cobra Mustang cassette deck - Manual eject
F3LF-19B165-AF
Came in:
1993-1993 Lincoln Mark 8
Sorry for digging up an old thread, but I recently bought a CD radio (F6TF-18C815-AA) with the flat faceplate and clock button. It works perfectly, but the faceplate has a chip in the top right corner. Mustang 5L5, do you happen to have a flat Fox-style faceplate that snaps on you’d be willing to sell? Button condition doesn’t matter since I can swap them—I’m just looking for one without cracks or chips.
Sorry, I do not have any more at this time. Kinda stopped putting these together once prices on them and parts got a little crazy
Gosh I'd love to install a Ford factory CD player in my 93. How do I verify that I even have the correct factory wiring?
Sorry for the hijacking!
For the Cd player and all electric cassette player you need the 93 Mustang amp and harness that has one flat plug for power and one square plug for sound as seen in this photo
the 93 amp harness will plug into the 92-87 harness but you will need to make either an adapter harness or to adapt your factory wiring
this is the adapter harness I made out of a few aftermarket adapter harnesses for aftermarket radio installs the adaptation that needs to be made is to power the amplifier from that far right pin in this case grey needs to be tapped into one of the 12+ voltage wires in this case red if you have any other questions feel free to send them to me
Reactions: 91GTstroked
Thank you! I believe I have a factory amp, if it's under the passenger seat?
Assuming you have a 93 it should be under the passenger seat and the plugs will be behind the radio if you have a 87-92 they didn’t come with this specific amp it’s a premium sound amp and the harness runs beneath the carpet instead they came with the football amp that is located behind the factory radio and has two square plugs
this is my football amp from my ‘91
this is the ‘93 premium sound amp I will be installing into my car to support my cd player install
Awesome . Yeah I have a 93 reef blue hatch with 27k miles. I have a aftermarket CD player.
I've considered going back to factory.
Reactions: TDM389
