Progress Thread finally tuning (and more)
What I don’t think you are understanding here is none of the instructions say to use any kind of lubricant at all. When you use lubricant and torque it to the same set value you are subjecting the threads to more tension stress than if assembling dry. This could result in pulling the threads.
Torque value for the lower to Ford aluminum heads is 16-18 ft-lbs or 192 - 216 in-lbs.
Read under “notes” in the NGK article:
Here’s the instructions that came with the heads. Last bullet point says use anti seize in reference to intake, exhaust and spark plugs.
And zero on a torque value and some vague BS about inaccurate torque wrenches. So if you strip them not their fault. This is why I use studs as it takes all the BS out of it.
Regardless great progress and it looks really good man.
Obviously you can see the air pipe going straight from the MAF to the TB. I’m going to run it NA for a little while before putting the blower back online. Probably do that in the fall.
I’m really glad I re-torqued the lower intake bolts. Remember when I initially did them I only put a small bit of wd40 on the threads. These’d bolts were already loose after the first heat cycle. 3 or 4 I could practically remove with my fingers. This time I put anti-seize on the threads and took them to 18ft/lbs. they’re good and snug now.
Got a slight intermittent rattle somewhere on the front of the engine. Maybe a missing or loose accessory bolt. I’ll update when I track it down
  • FacePalm
Reactions: gkomo
Air intake pipe was knocking against the shock tower and there was a couple of compressor bolts needed some extra snugging. I don’t hear the rattle anymore.
Here’s the A/F ratio at idle, FP 39psi vac off, timing 10 degrees spout out.
Now the car gets an exterior wash and I’m going to daily it for a week or so.
Can PLX make me a white-faced analog version of your multi-gauge with an amber backlight?
kthx :jester:
Mine is one of the earlier ones. If anything else is available I suppose they would list it at their website. I’ve got no complaints about PLX. Still working great for me
On my PLX I currently have vac/boost and AF. I just learned they have a fuel pressure module I can add to the chain. They didn’t have that before as I can remember. Be nice to have that available on demand.
Reactions: Noobz347
