Woke up way too early this afternoon, since I couldn't get back to sleep I ran out to the garage - Stumpy's subframe connectors are installed. Here are a few pics of the process:
First order of business was removing the forward spring support bolts and breaking the spot welds for the retaining nuts. I used breaker bar and was able to snap them off, then used a grinder with a cut off wheel to grind the remaining welds down.
As I said previously, I worked on the passenger subframe to get the connector to fit, the driver side was beat in worse than the passenger side but I was able to get it straightened out good enough.
Here is the driver side positioned into place to drill the 3 holes to bolt the connector in. I actually drilled 6 holes per side, the inner and the outer, instead of attempting to drill straight through. Unfortunately that means I had to drop my exhaust again.
Once the holes are drilled and the bolts inserted, release whatever load you have on your jacks and tighten them to the Gutentite torque spec.
