FUEL PUMP ALWAYS ON
Scwhitten
47
11
18
Ocala, FL
Ok, so you know when you turn the key to ON you hear fuel pump come on for a few seconds then shut off (at least I think that's what's supposed to happen)? Well when I turn the key to ON, I hear it, but it doesn't stop. Even after the car has started, I can still hear it from several feet way. Can anybody help me with this? The pump is new. I know people might want to jump right on that and say it came bad from the factory, but I just don't believe that is the case.
Thank you.....Scott
2001 Mustang GT
Only owner.
Thank you.....Scott
2001 Mustang GT
Only owner.
I will add that the tank is on Empty, there is enough gas to start it, but it's basically empty. Not sure if that matters.
New or old pump shouldn't matter, full or empty either way the ecu sends power the pump to prime then shuts it till the engine is running.
Your constant running is somewhere in the wires ,ecu, relay?
Reactions: Scwhitten
Yes, thank you for responding. The fuse is fine. I looked for the relay but my Chilton's doesn't talk about it other than showing it in the wiring diagram for the whole electrical system. YouTube says it is in the same box as the fuse but in my car, it is not. There are 5 relays in my fuse box (under the hood adjacent to the battery), none of them are the fuel pump relay, according to the owners manual that came with the car.
Would you know where it is In my car, 01 GT? I saw something about a relay behind the glove box, but I didn't think it was my model car.
Thanx again nickyb.
Try this:
Seriously? Why would they put in there, in a hidden box, sealed with rivets, then soldered to circuit board??? Great!!!!
So under the video, it says..."Most fuel pumps emit a low-pitched hum or whine that can be detected from within the car if you listen carefully or from the outside of the car, close to the fuel tank. When the fuel pump relay malfunctions, power will be cut off, rendering the pump inoperable and silent when the ignition is turned on." My problem is that fuel pump is only silenced with the key is in the OFF position.
So, not the relay?
Thanx Mcmahst for your response...
IDK, but you can probably test voltages from the box to determine if power is constant to the pump. Now, I’m not any kind of knowledgeable person on these years of Mustangs. You’ll need someone who knows the diagnosis steps to deal with this. Also, have you checked for codes? Most of the time, we skip that critical step. Good luck.
Reactions: DadLife0724
There isn’t a relay. Theres a fuel pump module in the trunk on the drivers side. Gets signal from the ECU.
Either a module issue or ECU issue here.
There is a relay in the CRMM which is hidden nicely underneath the front right fender, but people say they have never seen that go bad. I don't see the crmm in your diagram, are you sure that's a diagram for a 01 GT?
I know there's constant power to the pump because as soon as I turn the key, the pump comes on, and stays on after car starts up. I would love to see a very good drawing/schematic of the system....
Also, a few pics of the top of the engine so we can see what’s what. What I’m wondering is, does your fuel rail have a pressure transducer on it to measure the fuel pressure at the injectors? Again, no expert, if you can verify that, it might help. Also, did you run for codes? They are very useful for diagnosing. Good luck.
P0193 Fuel rail pressure high. I already tried the old one that I switched it out cuz of a different problem. It didn't fix that problem either.
I don’t even think I have a FP transducer. I know I have a FP sensor and a FP regulator but I haven’t seen any mention of a FP transducer. I have a brand new Fuel Pump. I’m going to plug it in and see if anything changes. At least if I plug it in and nothing changes then I’ll know the new pump that I put in is not bad from the factory.
Do you know if there is a code for the pressure transducer itself or the fuel pump driver module (FPDM) For what it’s worth, I suspect the FPDM is bad, but it would be great if there was a code for that. Good luck.
Your fuel pressure rail sensor has likely failed; why you have the code. Here is a helpful guide to resolving this code:
It’s either the rail sensor or a wiring problem. I hope it’s the sensor because wiring problems are no fun. Good luck.
Great article Mcmahst, thank you. What struct me was the empty fuel tank section. After replacing the fuel pump and fuel tank, I only put enough gas in it to start the engine. So, maybe there isn't enough gas in the tank. So I'm off to fill my 5 ga tank and come home and start putting gas in. Funny thing is, I asked about the no fuel in tank thing and somebody said it didn't matter. Fingers crossed. Thanx again Mcmahst...
Reactions: Mcmahst
