Fox Fuel Pump Issues After Replacement/Upgrade
Ryu
52
11
18
I've got a 93 LX 5.0 that I just replaced the fuel pump (after some quick research stock OEM fuel pump should be 88 LPH) to a 155 LPH from LMR, before install everything was "fine" (and I only say fine because I'm trying to fix a different issue by replacing the fuel pump in the first place) after install while driving it hard I would lose about 60-80% of power with the accelerator pressed to the floor usually after 2k rpm for 1st gear 2.5-3k rpm for 2nd and so on. I reinstalled the old fuel pump and the issue went away so i don't believe I installed the 155 fuel pump incorrectly or pinched any fuel lines nor do i believe there was air in the fuel lines because after reinstalling the old fuel pump I had no fuel delivery issues in the first place. doing more research I saw that for a 255 LPH pump the person who did that to their 92 coup also needed to install a larger guage wire to handle the volts needed to run that pump, do i need to do something similar? what should I do from here? becasue LMR doesn't offer a stock fuel pump
This is the kit I installed https://lmr.com/item/LRS-9350A/1986-97-Mustang-155-Lph-Walbro-Fuel-Pump
TL;DR:
  • my stock 1993 Mustang LX 5.0 ran normally before the fuel pump swap.
  • I replaced the factory ~88 LPH pump with a 155 LPH pump from LMR.
  • After the swap, the car would fall on its face under heavy throttle, losing roughly 60–80% of its power above ~2,000 RPM in 1st gear and ~2,500–3,000 RPM in higher gears.
  • Reinstalling the original fuel pump immediately fixed the issue.
  • Because the problem disappeared when the old pump went back in, I don't think the installation was incorrect, a fuel line was pinched, or air was trapped in the system.
  • I've read that some people running 255 LPH pumps on Fox-body Mustangs upgraded the fuel pump wiring to handle the increased current draw.
  • My question is whether a 155 LPH pump also requires a wiring upgrade, or if something else could be causing the power loss. or just something im missing completly
What's the issue?
Yes for a 255lph you should run a wiring upgrade kit. I have a 255lph walboro pump and am running my stock wiring. But, I am running the risk of not getting the full potential of the pump and worst case scenario could maybe melt some wires and start a fire? Not sure but that’s why I have an aeromotive wiring kit sitting in a box waiting to be installed. For a 155lph pump it’s ‘probably’ not needed but still a good idea anyways. That’s probably not your problem.
Maybe you got a defective pump? Have you done any other troubleshooting or just swapped pumps back?
Reactions: Ryu
I hate that these things come defective more often then not just in general. But that's my guess too but and I didn't even know how else to troubleshoot besides the reinstall of the original fuel pump not that I even want the 155 lph pump with current gas prices anyway. I'm looking at getting just a stock replacement on rock auto but before I did i wanted to see if maybe I missed some simple fix with the 155.
I’m going to say you got a bad pump. I ran a 255 lph pump on stock working for years with no issues. When I moved up in hp is when I started to see fuel delivery issues which is when I reworked the pump. It ensured I had a more constant voltage to the pump.
A 155 or 190 lph pump does not need upgraded wiring.
It’s pretty simple, old pump doesn’t exhibit the problems new one does so new pump is the issue. Try another pump but make sure it’s a genuine Walbro or Aeromotive.
Fuel pump has nothing to do with gas mileage. Engine will only burn what it needs hence the return system.
155 does not need upgraded wiring. I ran a 190 for years on stock wiring without any issues (that weren't of my own doing).
It might be in your best interest to get a fuel pressure gauge and actually monitor pressure during these events to determine if this is fuel related or other. Granted if swapping back to stock pump fixes it, it's likly a bad pump.
I was running a 190 and upgraded it to the 255 and have no issues with the stock wiring. I have mostly bolt on upgrades and haven't had any fuel issues in that past year that it's been installed. Walpro 255 comes with an E85 safe hose, where the 190 doesn't and after 20+ years with the 190 the rubber hose was almost totally broken down! Btw- LMR is the only place to get a replacement Fuel Pump Bracket Internal Return Cap as mine was also not in great shape. (orange rubber)
Reactions: Ryu
TL;DR:
When you increase the pump size you should put an adjustable fuel regulator to account for the increased pressure from the extra volume. and to dial in the pressure.
When you do the math a 155lph pump is enough to support 440hp.........
The extra fuel volume will cause your engine to run richer especially after the vacuum diminishes and the regulator raises the pressure more than the regulated 39psi wit vac hose disconnected and the engine running..You can put a gauge on the schrader valve to verify the pressure.
Pull the sparkplugs im gonna wager they come out black. unless your fuel filter hasnt been changed since the Bush administration...LOL
Another thing to note is that when you upgrade the fp its good to also change the fuelpump relay and replace it with one that is diode protected,,,The lil contact patch inside that transfers the power deosnt stay good forever and a slightly larger fuel pump equals a slightly larger power draw...
Good Luck
Reactions: Ryu
The stock fuel pressure regulator isn’t going to miraculously allow more pressure due to a higher volume fuel pump. Adjustable FPR’s are for tuning plain and simple. Plenty of cars out there with 255 lph pumps running the stock FPR so no need for an adjustable unless you want to run a different pressure with a tune.
TL;DR:
They do have a stock fuel pump at LMR
Oh, I see. That's why I couldn't find it. Because it comes as a whole set and I was looking for the fuel pump as a standalone. Oh, well, I got a 155lph from rock auto. For $29, so I saved some money. And I do have that one installed, so now I just have to test it. And see if it dies again. The two Scenarios that come to mind are one. It just never dies, and I actually did fix the problem. Finally, or it does die. And I now had to figure out what the heck else is causing this issue. What do you guys suggest my next steps be besides the checklist? I know about the checklisy although I'm not very confident in my skills in being able to apply the checklist to my situation, especially if it only dies. While driving, so I would be on the road while this happens.And then I'd have to do the checklist on the side of the road so not ideal. I could get a tow or just drive around town "hoping" it dies near my home so I can tow rope it home and diagnose it there. Besides that i also have a fuel pressure regulator and fuel pressure gauge being delivered soon.So, I'll be able to test whether or not if it does die.If the problem is that the fuel pump was or still is not delivering the correct amount of pressure...
Reactions: Mindseye007
If you look at the drivers side kicker panel and remove it you will find a couple of wiring plugs a bigger black plug look at the wires going in and out and look for a pink wire with black it is a tracer wire and it is tapped into the fuel pump wire check that and see if the wire is ok maybe it's melted a bit or the whole black plug could be melted a bit. Causing problems.
What fuel pump do you use now?
