Injector question
I just bought a 94 mustang GT and was wondering if these injectors are the correct ones for it. I've seen where they are and then they aren't.
So I bought the car with the cats taken off the car and looks like they were in the process of putting on short headers and then stopped working on it. It doesn't run without playing with the throttle. Put i looked at them when I was in the process of buying it and thought they didn't look stock so I looked them up and they said they where for a 4.6 liter not a 5.0. I just want to make sure they are correct or going to work so it doesnt run lean and I have a meltdown.
I run those cheap china Motorcrafts all the time
True the last set I put in had 1 bad one
46 bucks for 8
Just buy 8 more and replace them as needed
Otherwise, I just get known? good ones from the junkyard and clean those
Don't see many bad injectors, I see a lot that need cleaning
  • Informative
Reactions: DadLife0724
I doubt those are genuine injectors. Most likely Amazon/ebay knock offs.
The OE ford injectors will have a ford engineering part number on the top plastic and some have a ford oval (not all). I forget if it was Bosch or Denso making them in the early 90s.
Genuine replacement injectors won’t have the ford branding and engineering number, but I’ve never seen any with laser marking on the body either. That screams knock off to me
Ya i haven't had the time to take them out so check for more numbers. But I have a picture of a different angle that says they are cheap Bosch 19lb ones. Going to try them since they are on the car. Thanks everyone for the help! New to the mustang world and very excited to get her back up amd running.
