Fox Random spike voltage (Need help from scope users)
martroy
83
Canada
Hi everyone,
I'm chasing random voltage drop and would like to have help from scope users to see if the following behavior is normal.
When scoping battery voltage on post (yellow line) against pin 37 at EEC 60 pins connectors (blue line) when engine is running, I do have spike from pin 37.
When scoping battery voltage on alternator post (yellow line) against pin 37 at EEC 60 pins connectors (blue line) when engine is running, I get spike on both of them. It is normal to get this?
It's a brand new 3G alternator.
Any help would be appreciate. Thank you
What is the issue that prompted you to measure voltage there?
As far as I understand drop in voltage can be a loose/corroded connection or stressed wire.
Here's what I'm trying to find out the root cause of this.
When running without any specific behavior, it was registered in my logs (Megasquirt) voltage 14,5 to 14,0 for a split second. At first, I tought it was a MS issue but it's not since I do see the same outside of logs.
Now, basic stuff done like cable connection, ground, rust, bolt and found nothing really important for now.
Since scope seems a good tool to find out those thing that happens fast, I purchased one. (I'm new to this).
So my first question was is normal to see spike like this on the alternator stud compare to battery itself?
Thank you
Any 3G alternator, regardless of who makes it or where, will produce some voltage ripple. This is normal operation. The presence of ripple alone does not mean the alternator is defective.
The battery, on the other hand, is [not] an alternator. By itself, its DC voltage will be smooth. Connected to the charging circuit, it helps smooth the alternator’s voltage ripple. A smoother trace at the battery than at the alternator is expected.
Start with a voltmeter and perform voltage-drop tests across the cables, connections, and grounds under load. Seeing ripple on a scope does not, by itself, establish a voltage-drop problem.
Here is a YT video that describes how A/C alternators are converted into D/C voltage and why you get voltage ripples on an OSC:
View: https://www.youtube.com/watch?v=5cbQNfO0Mwg
Reactions: DadLife0724
Thank you for that good explanation, I tought ripple would be see only when AC coupling, not DC.
Lesson learned
You're not wrong. The alternator generates AC current that is then converted to DC.
The ripples you're seeing are the end of one coil (in the alternator) and/or the start of the new one (they overlap). It's also why the ripples all appear to be a set distance apart (120 degrees of rotation).
  • Informative
