Progress Thread The next "big" project for my Cobra - T-top conversion coming soon!
I am just shocked that you could pull the engine with the headers attached.
I have never used a intake plate to pull an engine as I have a strange fear the studs will pull out of the aluminum. Did the studs come with the plate?
No, the studs are the actual carb studs that held the throttle body. I left the 1/2" spacer between the plate and the manifold to account for the length of them. And I've always been able to pull the engine with these headers. They're the old Black Jacks that are essentially unobtainable. They'll also be getting a refreshed ceramic coating as this version has seen the end of its life and is flaking/peeling off. When I redid the car in '01 I had sent them to some outfit in Tennessee iirc. This time around they may get sent off to Jet Hot for the original coating in hopes it'll be a better product. :cross:
Jet Hot's quick quote for my headers.
And a before shot:
Reactions: DadLife0724
Do they prep the headers and if so I wonder if they take it down to bare metal? Back when I bought mine new (early 80's I'm guessing) I bet they were only $60 or $70 and now over $500 with shipping just to coat them! They sure are going to look amazing though.
Reactions: LILCBRA
I'm sure they do some sort of pre-treatment so the ceramic coating adheres to the parent material vs just being a second layer over whatever. If I had to guess they probably acid dip them. And mine will need a slight repair. It looks like the factory didn't do a good job on a weld - or the weld just magically disappeared. So that will need something done as well. I sent them a full set of pictures in my reply to give them a good idea what they have to work with. I've not heard anything back yet, which is understandable since I replied around 330 CST. They're only location now is in North Carolina so they were probably gone for the day when it was sent. But here's the other 2 pics I sent:
As for what they cost back in the day - if I recall, I paid something like $110 or $120 in the early to mid 90s. And, if I remember right, I ordered them through Western Auto along with the cam that's in the engine.
Speaking of the cam.... I've toyed with the idea of swapping it too while I'm doing all of this. Was looking at these options:
Keeping the 1.7 rockers with this cam
Or dropping back to 1.6 roller rockers with this one
or this one
Then, of course, I started thinking of stroking it to 331.....
:think:
Scope creep in full effect!
Nothing horribly exciting to report, but I got the dash and heater box removed from the Cobra on my night off last night. Also got a better look at the floors. They're really not quite as bad as I keep thinking that they are. I'll need to do a little patchwork on the toe boards on both sides with the passenger side being the worst, extending up beyond the radius. The driver side should only need a fairly small flat section, then the floor can be patched. I really think the worst of all of this will be the rockers....
And another invaluable upload from @IICrew
Here are some pdf's I've collected over the years. Most are from II.org or facebook. Alot will be covered in other posts. Some info may be outdated. I just wanted to make sure I didn't lose them and wanted another way for everyone to access them besides facebook.
I just used the wiring diagram PDF and sent off to have 11x17 laminated prints made. As long as they do a good job, they should work a lot better than the small print in my Haynes manual when I go to wire everything back up!
Taking a break from the progress to grab a bite - I've been at it for about 2-1/2 - 3 hours and got the old patches removed. here are a couple of the areas that will be getting replacement steel welded in. I think this might give a better picture of what I'm up against. I think one of the reasons is that when I went through the car the first time in "01 I sprayed the interior and underside with POR 15. I still have a couple of spots that are worse than they were back then that I'll share later, but I don't believe these holes grew from where they were back then. :shrug:
Basically ready to cut and fit the patches. :nice:
I set one of the new floor pans in place to check the fitment again. Turns out that the outer flange is actually in the right place, it's just bent the wrong way. :cautious:
Here's the bad spot I mentioned in my earlier post. This is the front driver's seat mounting location. Again, as I said, I coated both sides with POR 15 25 years ago. When I did that this area was solid. I had the car media blasted back then and it was clean steel at that time. I followed their directions as well. So I guess I don't know what to think of it - I mean it's been 25 years, but still - don't they claim that it's permanent if you use it as directed? :nonono:
The toe board patches are pretty much ready to go. I was going to start to burn them in but found that the partial box of self tapping screws that I thought I had were no where to be found. So I'm in a holding pattern until I can either find them or pick some up. I really think that getting the toe boards nailed down before cutting the replacement floor pans is the right move.... :shrug:
Reactions: RaggedGT
On a positive note: I found the self tapping screws this morning before I went to bed. It kind of dawned on me as I was getting ready to go to bed so I went out and checked. Low and behold there they were!
I went out there this afternoon when I got up, used my flange tool to punch a few holes in the passenger side patch and clamped/screwed it down. On another positive, my radius matches up almost perfectly!
I was about ready to burn it in, or so I thought....
I went to grab the weld through primer and found that I don't have any anymore. So I guess this is on hold again.... :nonono:
The weld through primer showed up earlier. So I went straight to the garage when I got out of bed this afternoon, cleaned up the weld areas again and shot them with the primer.
Then I came in the house to have some dinner, then went back out. I decided to cut the patch and give it a flange in a similar position as the stock flange, then commenced welding. Here's the result after tacking a thousand times, including sealing up pinholes that would rear their ugly head after grinding the welds down. Not perfect, but definitely better than the rusted area that was there to begin with. I don't think anyone will notice anything once seam sealer, sound deadener, and the torque box is installed. :)
And the rough-cut floor patch. As I think I said earlier, the flange was bent the opposite direction, so I had to clamp it up and hammer it back 180 degrees for it to fit "properly"
When I get back out there tomorrow, I'll get better marks to cut it closer to the cuts in the floor before I try to burn it in.
