Interior and Upholstery Double din and HVAC relocation
Kid wita 5oh
I'm definitely not in the original hole
1,413
151
93
Saugus, MA
Jus thought I'd share I did a double din radio on top and moved the HVAC to the bottom. Came out decent for my first attempt... Took a lot of trial and error ....I may redo the radio mount not sure yet
Designed and 3d printed the mount (very new at this kind of thing)
A small trim ring for the HVAC controller
Good morning ..im wondering about this havac relocation for the higher mounting for the stereo.i think its a dumb design where ford put the stereo.
Can you explain what you did to make this happen and any problems and solutions
Where did you get a trim ring for the HVAC!?
It might be just for foxbodies but there’s a guy who makes these trim kits to swap the double din radio and hvac controls… 717Fox, 919Fox… something like that. Maybe see if he makes them for other generation mustangs.
The kits are here for foxbody Mustangs
Just be warned. You will have to make permanent modification to your dash, so make sure this is what you want to do.
I designed and 3d printed both the radio mount and the trim ring for the HVAC controls.
And this is definitely not reversible.. I had to cut sections out where the original setup was
I will see what I have for progress pictures in the next few days and if I have any that show useful info I'll put them up
Sure I will upload it here next time I'm at my desktop.
Keep in mind, I designed it around a specific radio, not sure if it will fit all double dins or not
i feel like it's a gonna be a good template for a lot of other double dins. i think i might just get the same radio as yours to make it hassle free.
did you print anything to make the hvac controls looks so flush? it looks so factory made in the photo
Just saw this post. I made a trim ring for it. And mounting tabs. I will up load that tomorrow. It's not in the radio mount files.
The mounting tabs I just glued onto the factory trim piece with an abs slurry. (Also glued the trim ring the same way) And ran two small screws that I had laying around into the sides of the controller
