Media
front
front
side angle
side angle
Ford Racing 5.0L Aluminator XS Crate Engine M-6007-A50XS
Get more details on the Ford Racing Aluminator XS crate engine here: http://www.latemodelrestoration.com/item/M6007A50XS/Mustang-Coyote-50L-Aluminator-Xs-Crate-Engine-M-6007-A50XS If you want the ultimate 5.0L Coyote Engine for your 2011+ Mustang or Coyote Swap project look no further than the Ford Racing Aluminator XS crate engine (M-6007-A50XS). This 5.0L crate engine is manufactured with the highest quality performance parts from the oil pan to intake manifold. Some of these parts include Mahle forged pistons and Manley H-beam connecting rods used in the rotating assembly. The Heads feature CNC port and polished Boss 302 Cylinder heads and Ford Racing performance camshafts. To help this beast breathe FRPP included a Ford Racing Cobra Jet Intake Manifold and Throttle Body. To ensure the engine is properly lubricated the engine comes with a MASSIVE 12 qt Boss 302 oil pan. Click on the link above to see the complete list of performance parts that go into this amazing Mustang crate engine!
MMD bezels & custom matte paint
Paint shop work
Mustang Coyote Swap Road Racing @ TWS - Latemodel Restoration
Want more information about this Coyote Swap Mustang? Click Here: http://www.latemodelrestoration.com/products/Mustang-Coyote-Engine-Swap-Project Watch as the Latemodel Restoration Mustang Coyote Swap chases down Porsches, BMWs, Honda S200 and more at Texas World Speedway. Project Coyote Swap has performed amazing at every road race event it has attended. Be sure to check out our Coyote Swap Bondurant Cobra at Mid America Shelby Meet in Tulsa this June! Click on the link above to watch the complete build of this awesome SN95 Mustang! LatemodelRestoration.com 5.0Resto SVE
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Mustang Rear End Gear Installation: Ford Racing 8.8 Ring & Pinion
See our full line of Mustang Rear End Gears here: http://www.latemodelrestoration.com/products/Mustang-Rear-End-Gears Are you looking to improve your ET's? Nothing improves your acceleration and helps you launch your Stang like a set of Ford Racing Rear End Gears! The FRPP ring and pinion gear sets are available in multiple gear ratios for your Ford 8.8 rear end. Each gear set includes the pinion and ring gears, crush sleeve and pinion nut. Here at LatemodelRestoration.com we know that you need more than just the gears to finish off your installation. That is why we are the originators of the Mustang Rear Gear Kits! Each of our Gear Kits features all the needed parts for you properly install a new set of gears in your Mustang! We include only the best components in each kit. They begin with your choice of Ford Racing Rear End Gears (see below of available ratios) and then we throw in Ford Motorcraft Friction Modifier, Royal Purple Max Gear 75W-90 gear oil and finish it off with a master bearing & shim kit. Installation of your new ring and pinion gears should always be done by a mechanic with a good working knowledge of rear end gears! We put together this how to installation video to help walk you through the install process. If you feel at any point this removal and installation process is above your mechanical skill level -- you aren't alone. Make sure you take your Mustang and new gears to a good trustworthy shop with experience installing Ford 8.8 rear end gears. This video will help you have a better understanding of what questions you should be asking and what to look for in the installation! Changing your rear end gear ratio will require you to recalibrate your speedometer. For 83-95 Fox Body and SN95 Mustangs, you will need to replace your speedometer gear to fix your speedometer. Click the following link to see our speedometer gear calculator to properly select the correct speedometer gear - http://www.latemodelrestoration.com/products/Mustang-Speedometer-Gear-Calculator . If you have a 1996 to present Mustang your best fix is to pick up a SCT tuning device such as the SF3 handheld tuner to correct your speedometer. You can see our full line of SCT Tuners and Tech Videos here - http://www.latemodelrestoration.com/products/Mustang-SCT-Tuners . When replacing the ring and pinion gears on your Mustang don't forget to pick up a traction lok clutch repair kit or new traction lock differential. The clutches in the factory unit wear out over time -- especially with aggressive driving. Save yourself time and money by replacing these when installing new rear end gears!!!! See our full line of Mustang Traction Lock Differentials and Repair Parts here - http://www.latemodelrestoration.com/products/Mustang-Traction-Lock-Differentials Popular Gear Ratios: 3.08 3.15 3.27 3.31 3.55 3.73 4.10 4.56
My 89 GT turbo first startup
Purring like a kitten!
Mustang Clutch Installation (79-04 Fox Body & SN95)
Mustang Clutches, Flywheels & Accessories - See Them Here: http://www.latemodelrestoration.com/products/Mustang-Driveline Is the clutch in your Fox Body or SN95 Mustang slipping or making some awful noises? Then it is time to tackle the Mustang clutch replacement project! With the help of LatemodelRestoration.com, selecting the correct clutch, clutch components and installing your new clutch doesn't have to a major headache. We have plenty of tech articles to help you diagnose those all too common clutch problems and issues (see them below). We also have this clutch installation video to help you with your replacing your worn out clutch in your Stang. If at any point you still feel a little lost, you can also call any of our Mustang Enthusiasts customer service reps at 1-866-507-8871. Installing your new clutch will require roughly a full day from start to finish. Follow along in this video as Jmac walks you through all the major components of this project. Don't forget we have all the most popular clutch kits such as Ram and Exedy Clutches. We also have all the driveline components you need to finalize the installation. These include clutch cables, quadrants, firewall adjusters, flywheels, aluminum driveshafts and hardware. MUSTANG CLUTCH PROBLEMS & SOLUTIONS http://www.latemodelrestoration.com/products/Common-Mustang-Clutch-Problems-Causes-Solutions WHAT MANUAL TRANSMISSION IS IN MY MUSTANG? http://www.latemodelrestoration.com/products/Mustang-Transmissions-What-Transmission-V8-Mustang MUSTANG CLUTCH KIT BUYER'S GUIDE FOR RAM CLUTCHES http://www.latemodelrestoration.com/products/Mustang-Clutch-Kit-Buyer-Guide
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
