Media
Imported Item
Imported Item
New billet matte black GT emblems. Also available in chrome. Ford licensed. Made in USA.
Imported Item
Imported Item
New headlights are a huge improvement
Imported Item
Imported Item
Spring cleaning
Imported Item
Imported Item
After repairing and replacing some parts went and got it re-tuned. Much more repeatable now. Left it fat with 11.5a/f. 379rwph/383rwtq. Very happy with the results.
Imported Item
Imported Item
Fun in Miami Beach!
Imported Item
Imported Item
Getting the muffs installed
Imported Item
Imported Item
My baby
Imported Item
Imported Item
Imported Item
Imported Item
  • MNish MNish
  • Apr 5, 2013
  • 0 Comments
Imported Item
Imported Item
  • MNish MNish
  • Apr 5, 2013
  • 0 Comments
Imported Item
Imported Item
  • MNish MNish
  • Apr 5, 2013
  • 0 Comments
Imported Item
Imported Item
  • MNish MNish
  • Apr 5, 2013
  • 0 Comments
Imported Item
Imported Item
  • MNish MNish
  • Apr 5, 2013
  • 0 Comments
Imported Item
Imported Item
bought 5 of the 69 shelby wheels ,one will mount on the package tray inside the car with 245 -60 15 BFGs
Imported Item
Imported Item
i assembled the willwood disk brakes and mounted them on the spindles .
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Work In Progress
Imported Item
Imported Item
3g complete
Mustang SVE Lowering Springs (79-04)
FORD MUSTANG SVE LOWERING SPRINGS http://www.latemodelrestoration.com/item/SVE-5300A/Mustang-Lowering-Springs Part #: SVE-5300A Brand: SVE Fits: Mustang GT, Cobra without IRS (Independent Rear Suspension), Mach 1, Bullitt, & Foxbody Mustang with V8 Year Models: 1979 (79) - 1980 (80) - 1981 (81) - 1982 (82) - 1983 (83) - 1984 (84) - 1985 (85) - 1986 (86) - 1987 (87) - 1988 (88) - 1989 (89) - 1990 (90) - 1991 (91) - 1992 (92) - 1993 (93) - 1994 (94) - 1995 (95) - 1996 (96) - 1997 (97) - 1998 (98) - 1999 (99) - 2000 (00) - 2001 (01) - 2002 (02) - 2003 (03) - 2004 (04) Want amazing handling and a lower stance for your Mustang? How about at an affordable price? Well you can have all of these with the SVE Mustang Lowering Springs. These lowering springs are designed to cover 1979-2004 hardtop V8 Mustangs -- that means they will fit Fox Body Mustangs (coupe or hatchback) and SN 95 Mustangs with V8 and solid rear end. SVE Mustang lowering springs are made in the USA by a leading suspension engineering company and have been designed to our exact specifications for the best performance and appearance on the market. If your Mustang is in need of lowering springs whether you have a 79-93 Fox Body or a 94-04 SN95, we have the answer with our SVE Mustang Lowering Springs. The spring rates for the SVE lowering springs are 200/251 lb spring rate in the front and 571 lb spring rate in the rear This SVE Mustang Lowering Spring Kit lowers your Mustang up to 1.5 inches. See the information below for your specific Mustang model. * 79-93 5.0L Mustang Coupe and Hatchback (including Cobra) - 1.2" front/1.0" rear drop * 94-04 4.6/5.0L Mustang hardtop - 1.5" front/1.5" rear drop * 94-98 Cobra hardtop - 1.5" front/1.5" rear drop * 03-04 Mach 1 hardtop - 1.1" front/1.0" rear drop * 2001 Bullitt hardtop - 1.1" front/1.0" rear drop Will not fit 1999-04 Mustang Cobra with independent rear suspension (IRS). Not recommended for convertible Mustangs due to the difference in chassis weight compared to a coupe/hardtop. LatemodelRestoration.com
Mustang 5.0 Emblems: How To Remove & Install Fender Emblem
Mustang 5.0 Emblems: How to Remove, Install & Place http://www.latemodelrestoration.com/item/LRS-16228A/Mustang-Chrome-50L-Fender-Emblem Is it time to replace your 5.0 emblem on the side of your Fox Body Mustang? Maybe you have sent your Foxbody off to paint and you aren't sure exactly where the new 50 emblems should go back onto your Mustang. Most people may not realize that these were installed by hand on the Ford assembly line. Unlike later year model Mustangs, these did not use alignment tabs and holes in the fender. Thus making it hard to determine the exact spot these emblems show go back into. Follow along with Jmac as he shows you how to remove and install new 5.0L Mustang Emblems back into their proper place. The emblem removal process will work on any emblem that is held on with 3M style adhesive tape. MOLDING ADHESIVE ERASER TOOL WITH ARBOR http://www.latemodelrestoration.com/item/LRS-400E-KIT These emblems will fit the following year model Mustang GT LX SVT Cobra: 1979 (79) - 1980 (80) - 1981 (81) - 1982 (82) - 1983 (83) - 1984 (84) - 1985 (85) - 1986 (86) - 1987 (87) - 1988 (88) - 1989 (89) - 1990 (90) - 1991 (91) - 1992 (92) - 1993 (93)
Imported Item
Imported Item
2013 4x4 Off Road XLT
Imported Item
Imported Item
