Media
Imported Item
Imported Item
havent gotten stuck once.
Imported Item
Imported Item
a jeep through mud at me.
Imported Item
Imported Item
DSCF0061
Imported Item
Imported Item
DSCF0055
Imported Item
Imported Item
DSCF0059
Imported Item
Imported Item
DSCF0058
Imported Item
Imported Item
DSCF0057
Imported Item
Imported Item
new visors will be carpeted white with new mirrors and bfactory black covers with neon white lights
Imported Item
Imported Item
underside of hood. Hood to be removed and replaced by Spyder3 Carbon Fiber Hood
Imported Item
Imported Item
Battery is rigged with a clear floor matt and bungey cords. Will be replaced with 2 Optima Blue Top Batteries, both going to be wired to trunk. One for The Car System, and One for the car itself.
Imported Item
Imported Item
3.8 Litre V6 Motor, stock with 176,000 miles. Needs a head gasket. New plugs wires and oil change. Going to pul motor and install a custom built from block up 302 motor. :D
Imported Item
Imported Item
Under Trunk Third Brake Light wire cut. Going to be rewired anyways for a White L.E.D. Third brake Light With Custom Lettering
Imported Item
Imported Item
Trunk going to be cleaned, sand blasted and a layer of primer before being redisgned with fiberglass for custom trunk desing, including nitrous bottle and 2 Optima Blue top Batteries
Imported Item
Imported Item
All Pedals and accessories to be removed and new Steeda pedals and arms going to be installed
Imported Item
Imported Item
Hurst T-Handle going to be removed, a B&M Short Throw Shifter to be installed, custom two tone shift boot, and billet shift knob.
Imported Item
Imported Item
After Dash is repainted, and trim kit instaled, vents will be replaced with Billet Chrome Vents.
Imported Item
Imported Item
Defrost vents will also be Billet chrome
Imported Item
Imported Item
Back Seat Has already been removed belts, bolts and all(for sale 5/8/09) and custom back seat delete kit going to be installed.
Imported Item
Imported Item
Steering wheel and hub to be replaced with new Sparco Black and white Steering Wheel and short hub attachment. Carpet to be replaced and all doors, firewall, under carpet, and rear seat along with trunk to be sound matted and heat proofed.
Imported Item
Imported Item
Mirors to be replaced with MK3 Mirrors, power with white led turn signals
Imported Item
Imported Item
Pony trim grille missing. Going to be reinstaled with chrome grille and new chrome pony.
Imported Item
Imported Item
Front bumper bolted together
Imported Item
Imported Item
There are pieces of wood bolted together holding the front bumper together. Going to be removed and a Vade body kit with aluminum mesh installed
Imported Item
Imported Item
Front passenger headlight and corner busted. Both going to be replaced with JDM Projector Halo 2 Headlights with blue neon bulbs
