Media
Imported Item
Imported Item
Imported Item
Imported Item
The nasty little 306 is done and pulls hard
Imported Item
Imported Item
front to back drivetrain like new
Imported Item
Imported Item
Yes, everything that was removed that wasnt brand new was repainted
Imported Item
Imported Item
Worl Class T-5 Trans rebuild
Imported Item
Imported Item
That 3/8 hose is actually an extra intank pickup hose I had, when the pump is mounted here its the perfect fit to the filter
Imported Item
Imported Item
fuel pump wusing stock plastic supply line slid over a barbed nipple works perfect and almost looks factory
Imported Item
Imported Item
More harness assembly
Imported Item
Imported Item
Custom harness creation begins
Imported Item
Imported Item
MSD 6AL Box
Imported Item
Imported Item
Empty bay starting from scratch
Imported Item
Imported Item
Engine built but before install
Imported Item
Imported Item
Pretty large ports for small block heads
Imported Item
Imported Item
Stock paint painted and hammer clearenced for Canton windage tray
Imported Item
Imported Item
struts & the cc plates
Imported Item
Imported Item
SN95 spindles, holding 03 rotors, dual piston PBR calipers, Hawk pads, MM ss brake lines, MM bump steer kit, Lakewood 70/30's and Eibach prokit springs
Imported Item
Imported Item
Flamming River manual rack
Imported Item
Imported Item
The 31 spline Moser axled rear I built that houses 4.10's and an 8 clutch disc posi, had drums on it in the pic, now its rocking disc brakes.
Imported Item
Imported Item
k member wire wheeled and painted
Imported Item
Imported Item
Rear suspension consisting of Eibach springs (4 cyl's now), MM double adj uppers, UPR lowers, Lakewood 50/50 and full length subframes.
Imported Item
Imported Item
mustang rear
Imported Item
Imported Item
mustang front
Imported Item
Imported Item
29
Imported Item
Imported Item
10
