0.28 seconds
I would like to get my car into the 13s this coming spring, but im short on cash. I could use some good suggestions on dropping 0.28 seconds (at least, more would be nice) without breaking the bank. I'll probably have $250-300 to spend. I'm in the market for an o/r x-pipe but i think i'm gonna need more than that. Oh and i want to stay with the stock 3.27s right now so no gears.
Thanks
Thanks
250-300 dollars isnt much to work with to drop that low. I would say an easy way to do this cheap is just start unbolting unnecessary parts from the car. remove passenger seat, rear seat, spare tire, AC and stuff like that. drop about 200lbs and then work on a better launch and you got it. 300 dollars worth of performance parts are not going to do it. unless you find a cheap used nitrous system then it can be done.
i spent like 1000 dollars in boltons just dropping my car about .3 seconds lol. basically the cheapest way to drop time is nitrous. actually quite a bit more than 1000 dollars because my exhaust stuff alone was about a grand. lol going fast is not cheap.
Yeah i didnt think it was gonna be posible with that little cash. I was hoping to maybe get lucky and beat my brother to the 13s. He's got a 02 gt with a Mac cold air kit, Mac o/r h-pipe, Mangaflow xhuast(mangapac mufflers), 3.73s and Nitto drs.
But his best time is a 1.98 60' and 14.03 @ 98.36mph so im not too far off
bro i bought a wet kit able to spray 150 for $180 with everything on craiglist, so spray and buy some used radials and put them on some V6 rims. spay a 150 shot and youll be 13.0 or high 12's. remember do mods that will give you power not usless ones like x-pipe or cold air intake.
dont gut your car out man!!! how the hell you going to take your girl out if you do that. the hole point is to have a quick car with drivability, and the after market x pipe will help but you wont notice the diffrence at all
easy, offroad mid pipe, pullies and timing adjuster. It's worth 3 tenths. Should be about 300-400 bucks. Also, take that 78mm tb and plenum off and use the stock one.
you don't have to gut the car, it takes 20 minutes to remove the seats, spare. It takes 20 minutes to put it back in.
