I used a positive stop to find true TDC on my balancer. The current 0 mark was 2 degrees off in the advanced direction. I'll remark and install timing tape so I'm good from here on out.
My brain is struggling (happens frequently). Since my 0 mark was incorrectly advanced by 2 degrees, that means my actual initial timing was 2 degrees more retarded than I thought. Is this correct or do I have it backwards?
The new 0 mark will be 2 degrees on the ATDC side of the factory 0 mark if that helps explain things.
