01-04 Functional Hood Scoop....
  • Thread starter Thread starter jdmsi94
  • Start date Start date Jun 9, 2007
jdmsi94
DFW, TX
Jun 9, 2007
  • Jun 9, 2007
Can it be done and what are the negatives?
XxMustang281xX
194
Everett, PA
Jun 9, 2007
  • Jun 9, 2007
anything can be done. shouldnt be that hard. only negatives are more speeding tickets because you'll be going faster with the ram air. lol.
i think you might need to fasten the hoodscoop down better so it doesnt blow off. get a hood scoop and i have a stock 99-00 GT hood to put it on
AvalancheSVT
573
37
49
Jun 9, 2007
  • Jun 9, 2007
the only thing i really dislike about these cars is the abundance of non functional "vents" on the car. get a 03 cobra hood and be done with it or do a mach1 stylee shaker if ya really want "ram" air.
oh and it really ain't ram air. if you want ram air buy a blower.
XxMustang281xX
194
Everett, PA
Jun 9, 2007
  • Jun 9, 2007
i have an 03 cobra hood but im still getting the inserts in the vents..then its not functional is it???
whyask
735
Sacramento
Jun 9, 2007
  • Jun 9, 2007
were did you get your inserts...??
It can be done, BUT, the rain will get in to your engine bay and over time build up alot of rust. Someone did a stock 03 gt hood scoop and made it work but it looked like azz and rusted out half his engine bay...
XxMustang281xX
194
Everett, PA
Jun 9, 2007
  • Jun 9, 2007
you wash your engine bay though (sometimes, lol)...and im getting my scoop inserts from randy stinchcomb from mustangboards.com
F
FalconGuy016
437
Northern VA
Jun 9, 2007
  • Jun 9, 2007
Not supposed to.
mransr
1,188
36
98
Riverside, SoCal
Jun 9, 2007
  • Jun 9, 2007
it's already functional...it's function is to make the car look better
seriously, what exactly do you want the scoop to do?...it's nowhere near the actual air intake for the engine, and by the time you'd plumb it to the air-box you'd have lost most of the advantage of the scoop (see the Mach1 scoop for example)
jdmsi94
DFW, TX
Jun 10, 2007
  • Jun 10, 2007
I am just looking for a way to cool the engine down a little. I was worried about the rain though.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 10, 2007
#10
  • Jun 10, 2007
  • #10
It is normal to want to make your stock hood scoop functional. It is wrong to actually do so...
Mustang5L5
Mod Dude
Feb 18, 2001
43,378
18,123
224
Massachusetts
Jun 10, 2007
#11
  • Jun 10, 2007
  • #11
It's a bad idea. There are no positives, only negatives.
There was a post here last year by a guy who did this. He daily drove it so in the rain, water would go into the scoop. He ended up having to replace 3 or 4 coil packs due to water damage and when he took his spark plugs out there were completely rusted up. He had other water damage as well.
It will make the top of your motor filthy as hell as well.
Also, the scoop is too low in the airstream to do much good. Mach 1 guys have to lift their scoops up just to grab fresh air. The scoop is low for aerodynamic reasons. Also, the grill being closed off is for aerodynamic reasons as well. If you were to open up the grill or remove the insert, you would actually create more drag on your car.
In other words...leave it alone
mark95turbo
Illinois
Jun 10, 2007
#12
  • Jun 10, 2007
  • #12
MakotoS13 said:
get a 03 cobra hood and be done with.........
Bingo! I thought all of the fake scoops and plastic honeycomb looked like crap so I got an 03 cobra hood and grill delete. With the little scoops behind the door only being left I am alot more pleased with the looks of the car.
blkhorse
345
Jun 10, 2007
#13
  • Jun 10, 2007
  • #13
opening up my scoop helped me,it blows air right on the air intake/rear of blower,lowering my ait's by sometimes 15 deg's on hot day's.I am making a soft rubber insert that is easy to install on those rainy day's.it also allows trapped heat to dissapate when shut down. have not noticed any negative effects,Glad I did it,looks good too
d98gt
4,505
59
204
SE Texas
Jun 10, 2007
#14
  • Jun 10, 2007
  • #14
http://forums.stangnet.com/showthread.php?t=653402&highlight=hood
EPIK
796
LEFT COAST
Jun 10, 2007
#15
  • Jun 10, 2007
  • #15
What are you talkin about, my shaker scoop adds like 50 hp or so!!!LOL
Y
Yellow2002GT
148
Raeford, NC/ FT Bragg
Jun 10, 2007
#16
  • Jun 10, 2007
  • #16
I am the one who did it and yes it caused a few problems...........but there were soulutions.....
1. It will cause rain to enter the bay.....it wasn't good with the stock boots on the COP's....they didn't seal well.....found a fix
2. It fouled out 1 coil plugs because the spark plugs got soaked......the coil was grounding out because the plug got wet.........I bought a set of Granitelli COP boots and wires......lets just say I pressure wash my engine weekly and no water gets past these baby's......
3. You have to make a small center piece to hold the scoop in place otherwise it will bow and pull away.......
4. It definately keeps the engine bay cooler when freeway driving.......would probably work well with a roots style blower...........
Honestly.......i wouldn't do it again, but it works great if you do it right and get the silicon boots for the plugs......they are slightly larger and seal the plug completely...as far as debris.......you get just as much from the bottom as you do from the top........
blkhorse
345
Jun 10, 2007
#17
  • Jun 10, 2007
  • #17
I don't have problems with the scoop bowing or anything,however,my car is a 99 limited edition and my hood is basically.99-00 hood with a scoop bolted on.so the piece I cut out faces the air flow about 45 deg rearward(right at my intake).instead of the hole beeing cut on same plane as hood.probally makes the difference
Need dimensions for hood scoop install
  • Mustang5L5
  • Sep 19, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 15, 2025
Mustang5L5
2003-04 Mustang Cobra Brake Conversion
  • Cassiebaebae
  • Oct 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 24, 2026
Bib36`
What's it Worth? 2000 GT
  • Mustang5L5
  • May 8, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jun 13, 2026
KRUISR
J
Fox Lost all gauge cluster function after Holley Terminator X install (solved)
  • Justin17383
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 13, 2026
2000xp8
C
Fox 1993 LX 2.3 Wiring
  • Coyoteswap93
  • Jul 13, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2026
AeroCoupe
