01 GT 24lb. injectors?
95blacksnake
24
Just wondering if 24lb. injectors from a cobra would work on my 01GT motor? If so what will i need to do to calibrate the mass air meter for them, and will i need to do anything to the computer?
I will be running a NX wet kit. I will more than likely just run a 100-125 shot so i don't pop the intake on the 150. Just figured it would be a lil safer.
DBMSTNG said:
you will need the car tuned for the injectors. you really don't need to upgrade the injectors unless you have some major n/a mods like cams and P&P heads.
ah, i see. i believe the 19/21lb injectors support near 300rwhp. i'm not sure how much the 24's will support. you may want to post this question in the power adder forum.
