01 gt motor swap to 00 gt roller crank no start
I have a 01 gt motor and trans I put in my 00 roller. Everything is wired up and ready to go, I get a crank no start with no anti theft light coming on. The anti theft light shows up when i turn the key to on position but turn off after like 3 seconds. I got no spark at no 1 plug and i do have fuel pressure at the rail. I did use the 01 gt harness and used it as plug and play not too sure if that is my problem. I had the roller out for a little bit with the hood lob sided and moisture may have gotten on the main plug as well as a few others. Where can I check besides obviously cleaning them out. I used QD electric cleaner on all the pigtails. Not too sure what to check next and help would be great
This is good. Likely means PATS is OK.
It would be handy to know:
  • There is confirmed key on 12 volts at each COP
  • There is confirmed key on 12 volt at each fuel injector.
  • Using a "noid" style test light, confirm that there's a fuel injector "pulse" during cranking.
Here's some more information that may help.
1996+ Crank with no start check list
Do you have an ODB2 scanner? It could provide a huge leg up on this problem.
ForScan ODB2 scanner w ELM327 USB
