  • SN95 4.6L Mustang Tech
02 About to Supercharge
  • Thread starter Thread starter 02gt4u
  • Start date Start date Dec 29, 2004
02gt4u
9
CALIFORNIA
Dec 29, 2004
  • Dec 29, 2004
I have an 02 GT with 50k miles on it. Is it worth putting a s/c on it or will it not last another 50k with the s/c on it? Im looking only like maybe 6psi KB. Whats your guys opinions?
Tylerb59
Banned
Mar 7, 2003
1,895
Arlington, WA
Dec 29, 2004
  • Dec 29, 2004
Go for the KB 9psi kit.
www.kennebell.net
It'll last for a while if you keep it out of the RPMs and have SOME self restraint. That and it might be a good idea to invest in a tire company.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Dec 29, 2004
  • Dec 29, 2004
Are you kidding.....that's barely broken in. The 4.6L in my Cougar had 235,000km on the clock before I tore it down to beef up the internals. The cylinder walls still had the original cross hatched pattern in them and the bearing were barely worn.
I wouldn’t worry in the slightest about strapping a blower to an engine with so little mileage on it.
jstreet0204
939
Winston Salem, NC
Dec 29, 2004
  • Dec 29, 2004
if your car has been well maintained and you have a safe tune, you won't have any problems. There are plenty of guys pushing 200,000 miles on supercharged motors. It wouldn't hurt to do a compression test before you make the investment.
281Ponies
190
  • Dec 29, 2004
Wise advise.
I remember seeing pictures of that engine on here a while back it seems.
-Cale
project91
101
  • Dec 29, 2004
I'd say go for a centrifugal to keep the stock drivability on the lower end of the powerband.
ATI Procharger: P1SC, D1SC
Vortec: V-1 S-Trim, V-2 SQ-Trim
Paxton: Novi 2000, Novi 1000
jstreet0204
939
Winston Salem, NC
Dec 29, 2004
  • Dec 29, 2004
All of the positive displacement blowers for these cars have bypass valves, so part throttle drivablity is not effected.
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Dec 29, 2004
  • Dec 29, 2004
Positive displacement blowers drive stock as a rock until you start putting your foot in it. The only issue after that is the smile that all of that low end grunt puts on your face.
As a matter of fact, drivability is often far better with a positive displacement set-up. Most systems will pull hard all of the way up to redline and you don't have to step up the gearing to pick up the low-end like you do with a centrifugal.
Regardless, it's been shown that either system work well with a 4.6L, whether it be street or the track. You've just got to decide where you want the majority of the power to hit. Stock grunt down low, with power in the mid/high ranges with a centrifugal? Or brute torque in the low/mid ranges, tapering off up top with a positive displacement system?
D
Darkhorse845
Banned
Nov 17, 2004
101
Las Vegas,Nevada
Dec 30, 2004
  • Dec 30, 2004
The ATI Procharger P1SC is a great blower.
dmarco_4u
194
#10
  • Dec 30, 2004
  • #10
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2026
skidad
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
I
2023 mustang gt fastback help
  • Izhar8709
  • Mar 22, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 23, 2026
LILCBRA
E
Chasing Vacuum leak 99 GT
  • EBNS_2005
  • May 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 3, 2026
X-cam34
