02 gt spindles with 01 cobra brakes?
93project
549
52
38
El Paso, tx
Guys I have 02 pbr calipers on my fox right now.... I was checking at work and I can order 01 cobra brakes, rotors, calipers, and caliper brackets ... Will they just bolt to the 02 gt spindles and brake lines?
Sweet! I've got 02 brake lines already. I also have the 95 booster/master setup. Weird thing... The caliper brackets are what will take the longest to get.. Special order at $30 a pop. Once I get this done, I'll start on the rear.
Which master are you running?
I'd it's the 94-95 GT/v6 master, you might find the pedal a tad stiff. You want a 1" bore mc (1993 cobra)
Sent from my iPhone 4S using Tapatalk
It's actually less. You have 44.5 mm pistons now (2 per caliper)
Cobras use 38mm pistons (94-98) or 40mm pistons (99-04)
That's why a slightly smaller bore mc might give you the feel you need.
Try the one you have, but if it feels stiff, keep this in mind
Thanks man. I'll get this going next weekend hopefully
