I've noticed my o2 sensors haven't worked since I bought my car about a year and a half ago. The car had one o2 sensor plugged in, and the other had the wires cut. So I replaced both o2 sensors. I get check engine codes for both sensors failing to turn on as well as terrible gas mileage and black tailpipes. I think it's safe to say they aren't working. Someone suggested to me that my o2 sensor harness might be to blame. I checked it with a multimeter last night and every wire can carry a signal. So that's not it.
It's possible that I just bought the wrong type of o2 sensors but I really doubt that since it plugs in perfectly and is a 3 wire type. I'm not the type of person that just randomly buys things in the hope of fixing a problem (because I can't afford to.)
I was thinking of testing the harness with the car on and running and seeing if the plugs that go to the o2 sensors are getting any voltage. That way if they still aren't, it could be because of the harness before it, or another problem. Would that be a good way to test it? Anybody have any idea about what voltage I should be seeing at the o2 sensor plugs?
