  • SN95 4.6L Mustang Tech
02 Sensor
  • Thread starter Thread starter 03sonicbluevirt
  • Start date Start date Oct 10, 2005
03sonicbluevirt
  • Oct 10, 2005
BAD 02 Sensor
I Recently Got An Of Road X Pipe Installed, Which Made My 02 Sensor Go Off. Its The One Thats In Front Of The Header On The Drivers Side. Know When I First Got The Pipe Installed The Shop Didnt Hook It Up Right It Leaked At The Header Connection. At First I Thought That Mught Of Made My 02 Go Bad. I Hade The Shop Fix The Leak, And I Replaced The 02. It Stayed Off For 60 Miles And Kicked Back On. Can Any One Help Me. Cant Figure Out Whats Up. The Code It Threw Was P0153 Obdii
RandyStinchcomb
1,159
Randallstown, Md
Oct 10, 2005
  • Oct 10, 2005
PO153 is a code for a lazy O2 sensor, get a new one from Ford and be done wth it.
03sonicbluevirt
  • Oct 10, 2005
I Did Buy A New O2 And It Stayed Off For 60 Miles Then It Turned Back On.
RandyStinchcomb
1,159
Randallstown, Md
Oct 10, 2005
  • Oct 10, 2005
did you buy one from a parts store or a Ford dealer?
sgarlic
3,085
Oct 10, 2005
  • Oct 10, 2005
If the o2 sensor was a Ford brand, I'd recommend re-checking the whole thing for exhaust leaks.
Stang|ess
seeking cyber partner(s)
Oct 18, 2003
941
Hawaii
Oct 10, 2005
  • Oct 10, 2005
Did you reset the ecu? Disconnect the negative terminal for about 15 minutes and reconnect it.
03sonicbluevirt
  • Oct 10, 2005
the 02 that i bought is from auto zone.
i did reset the ecu by taking the negative terminal off the battery.
it still kicked on the o2 is made by bosch (dont know if that is how u spell it)
the guy at ford told me to switch the o2's around and see waht happens
i have mil's pluged in to the back sensors.
RandyStinchcomb
1,159
Randallstown, Md
Oct 10, 2005
  • Oct 10, 2005
well there is your first problem, buying the O2 from a parts store. eventhough the Ford ones are made by Bosch, there made to tighter specs. the Bosch O2 you bought might fit Toyotas, Mopars, GM products and any other type of car. thats why when it comes to sensitive electronic stuff, go wth the factory/oem stuff as it made to work wthin Fords parameters not the whole aftermarket.
CanadaStang
2,093
Mb
Oct 10, 2005
  • Oct 10, 2005
what he said ^^
03sonicbluevirt
#10
  • Oct 10, 2005
  • #10
The Guy At Auto Zone Said It Was Oem For Ford .
03sonicbluevirt
#11
  • Oct 10, 2005
  • #11
And Dosnt Motorcraft Make The Ones For Ford
CanadaStang
2,093
Mb
Oct 10, 2005
#12
  • Oct 10, 2005
  • #12
Actually Bosch makes the Motorcraft 02 sensors, but the sensors they make for Motorcraft are made to Ford standards not industry.
03sonicbluevirt
#13
  • Oct 12, 2005
  • #13
k
thanks for the help. i will buy new 02 and see if that works. i also had the guys where i bought the x pipe send me a new flange. iim hopeing that the one the guys made to fix the leak is not right and all i need is the right size sleve. the shop that sold me the x pipe said that it needs to be a spacific size. have any of u guys ever heard of that. thanks for ur help.
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
  • Gulftown980x
  • Jul 29, 2026
squeak93
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
