well, i test drove this 02 stang w/ a procharger p1sc (8lb pulley), 3 core intercooler, 42lb injectors, 3.73 gears, mac catback, pro 5.0 shifter, and eibach springs (otherwise stock tb, plenum, pullies, headers, midpipe, maf). He said the owner before him dyno tuned it and got around 340 rwhp. He has gone to the track once and ran a low 14, then a high 13, then a 13.4 by playing w/ tire pressure of the 315 rears. I asked if he had bothered icing the intake and such but he said no. Others told him it should be running around a 13 flat. I'd think faster, like 12.5? He also said he most likely lacks some skill. When i test drove it it sorda felt slow...maybe cuz im used to driving my sti
i was pretty much idleing in 1st and nailed it and it started roating the tires after bout 3k rpms and i shifted into second around 5600 rpm where it continued to roast them a bit until i let off. i just dont know, i guess im trying to ask if this seems like it is as fast as it should be and worth the $15,900 id be paying. And how much power would be able to be picked up with the addition of an x pipe, tb, plenum and retune? Possibly some blower cams too.
Yea if you want to increase the chance of the bottom end letting go. 8 PSI is about all you want to go...with all the boltons (LTs included) 8PSI can push you to the "limit" of 420RWHP. I wouldnt up anymore than that....you CAN, but you start running into reliability issues...and you would need to get a new fuel pump setup for sure. That will run you into slot of little things. These engines arent made to make alot of powa.
...I know of too many people that have got greedy and did what you guys are suggesting....and they dont have their stock short blocks in the cars right now.
