03 Cobra Irs Problem.
WHYTRI03
I have a 2003 Cobra with a stock IRS. I had a 4 wheel alignment. The car drives to the left under hard acceleration. I feel the rear end push to the right. The problem is in the IRS. I'm thinking it may be the end links, but I really don't know.
If you have had this problem, and fixed it, or are an expert, I would really appreciate your help to solve my problem.
Thank you
Gary Huff
Thank you
Gary Huff
I had same issue...1 loose part..inner tie rod link..
got new part from full tilt boogie...
another area..front of rear sub frame bolts..ford put in wrong size...it should have 14mm/9/16 bolts
its funny that you say that. Because during the original alignment we had to replace one of the tie rod ends. I suspect that may be at the heart of the problem.that said, I'm going to replace all the bushings and all the tie rods.
