03 control arm install questions
chaos254
467
NJ
I just started on my install of the 03 front control arms, 00 cobra r tie rod ends and C springs. So far i've run into a couple of problems especially since my impact gun is broke so I couldn't take the top strut bolt off... just took the the bottom strut bolts out so the strut is still there but really isn't in the way. How do I get the balljoint nut off without an impact gun? Also the same for the tie rod ends...
i've done plenty of searches and even though i found some install guides none of them were very thorough. Most skipped steps and none of them mentioned anything about the ball joint nuts or tie rods.
LoudToy958
435
Bremerton, WA
I found using a tie rod end puller works great for taking tie rod ends and ball joints off. Worked like a charm all 4 times I've used it. You can rent one at Autozone.
However, I have never had the issue with the top strut nut. I have the bilsteins, and they have a allen keyway to aid in manual removal.
Good luck. Just be patient. It gets kinda nerve racking.
