my95gtstang
i know i read it. you can bore a motor over and stroke it. the stroker kits are built for a bore. thats why i cant actually order the kit until after the machine shop tells me if i can get a .30, .20 or whatever it is i can bore it to. it all depends. i didnt mean just to buy the kit and throw it on, i ment to buy the kit and build it that way.
The reasons you just explained on the EEC system is the reason he SHOULD go carb! One issue is your brakes. . . you will have to order a kit from strange and will have to mount fox spindals on the front in order to get the strange brakes to fit. The brake system in your car is hydro and actually runs off the powersteering. . . . You need a vac assisted or manual brakes, i would suggest going manual if you plan to run a larger camshaft. I know this because we just got done putting a 408 in my buddies 02 gt. If you have any questions of the swap shoot me a PM and i can tell just about everything you need to know to do the swap
