03 Gt Woes
adamv7010
43
Recently got into mustangs...but not to automotive performance.
Recently bought an 03 gt with a leaking intake manifold...
I replaced that with a new frpp manifold.
Before the swap I had a condition where it would stumble at idle a little, then during wot pulls it would act as if it were starving for fuel.
I really figured the leak was soaking a plug or two causing a misfire. I blew the plug bores out with air when I had the Mani off and got some liquid out of a couple.
I put it all back together and everything went smoothly. I replaced the gasket on the IAC simply because the ford store didn't have a valve on the shelf.
Long story short, with the new intake and dry plugs, I've still got a stumble at idle, which according to my live wire, is around 680-710rpm.
Anyone wanna guide me to a starting point? Are these 2v coils known for breaking up?
I have several k$ worth of diagnostic tools, but I don't have an IDS, so I can view most anything, just can't flash.
Any advice is welcomed.
Thanks
Adam
jcgafford
1,114
94
104
Adrian, MI
Those 4.6 liters are known for a couple different spots that fray vacuum lines and cause problems like this. Also if the iac is not a fomoco part I bet it is either causing you problems or is about to and it will not throw a code
adamv7010
43
It is a fomoco part...how old it is I can't say.
I do have it running pretty good now. The short eBay cai that the po put on it went away and it got a better one from late model...that made a good bit of difference.
Cleaning the maf made the most difference however
jcgafford
1,114
94
104
Adrian, MI
The fomoco iac in my wifes 4.6 was the start of 2 years of problem solving till a replacement fomoco iac totally fixed all symptoms. Ridiculous how badly that stupid little part can screw with that engine.
